Home > Forums > Software User Forums > SU2
SU2_DEF Fails During CGNS To SU2 Conversion
Like Tree1Likes
  • 1 Post By bigfootedrockmidget
Old   February 10, 2024, 12:03
Default SU2_DEF Fails During CGNS To SU2 Conversion
Freelancer1331 is on a distinguished road
I am trying to convert a CGNS mesh produced by Ansys Fluent to the SU2 format, but SU2_DEF crashes with a "SU2_DEF.exe has stopped working" error window during the read-in of the CGNS file.
Looking in Event Viewer, I get exception code 0xc0000005 which I think indicates a memory access issue. Curious if anyone else has run into this issue before or has ideas on where to look next. Thanks in advance.
CGNS file info:
From Ansys Fluent 2023
3D, single zone, ~18M elements (tetrahedrals)
CGNS is open-able with ParaView
SU2 version info:
V8.0.0 MPI
MS MPI v10.1.2
Run via PowerShell
PC:
Windows 10 x64
CPU 8C/16T
64GB RAM (passed MemTest)
Freelancer1331 is offline   Reply With Quote
Old   February 11, 2024, 05:01
bigfoot
bigfootedrockmidget is on a distinguished road
I had difficulty using the new cgns format, even Fluent still has difficulty writing this under certain circumstances. Did you try the legacy cgns .ADF format?
giovanni.medici likes this.
bigfootedrockmidget is offline   Reply With Quote
Old   February 11, 2024, 10:59
Ah, looks like that was the problem. Fluent was configured to export ADF v4.3. Changing to v3.3 resulted in a successful conversion to .SU2.
Thanks!
Salome cgns format mesh to SU2 JPBLourenco SU2 19 November 18, 2019 03:11
CGNS Boundary conditions using SU2 denzell SU2 3 July 9, 2018 06:58
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Issues with CGNS formatted mesh in SU2 jlwhelan28 SU2 5 February 13, 2017 12:48
SU2 not built with CGNS support. maximus23 SU2 Installation 5 May 11, 2016 13:05
