January 9, 2024, 19:59 |
Inverse Design - Incompressible solver
A Roy
Rep Power: 4 |
Hello SU2 community,
Is inverse design possible on the INC_RANS solver in SU2? I am able to run inverse design cases no problem in the compressible solver, but whether in my full case setup, or with the NACA0012 inverse design test case as a model scenario, I am unable to get the shape_optimization.py script to run beyond the flow calculation - the error message i get (attached below for the NACA0012 inverse design case) is very similar to that which is referred to in the following CFD-Online and github links, but it looks like the resolution of Issue 1727 seems to be already implemented into the historyMap.py file within SU2 8.0.0 - Harrier. Please help if anybody is able to advise a fix for the above, thank you kindly! |
January 16, 2024, 04:57 |
bigfoot
Rep Power: 21 |
Yes, inverse design also works for incompressible flows. I do not use these scripts, maybe there are some compressible specific lines in there.
January 16, 2024, 11:50 |
A Roy
Rep Power: 4 |
Fair enough, I will take a closer look; thank you for the confirmation!
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 07:12 |
How to use a solver repeatedly for design optimization | HoneyBadger | OpenFOAM Running, Solving & CFD | 2 | January 17, 2019 20:25 |
Problem with Inverse design of a 2D cascade | Bartosz.Ziegler | SU2 Shape Design | 10 | February 17, 2016 13:50 |
Modify compressible solver to incompressible | mingzhao | OpenFOAM Programming & Development | 0 | September 18, 2015 18:46 |
