Home > Forums > Software User Forums > SU2
Pitching Simulation
Old   September 17, 2023, 16:11
Default Pitching Simulation
Sigi is on a distinguished road
Hello everyone,
I'm currently running a simulation involving a pitching airfoil at a specific frequency. In this simulation, I've applied FFT in Matlab to analyze the x and y coordinates of the airfoil's motion over multiple periods. What's interesting is that both the primary frequency of oscillation and higher harmonics of that frequency are present in both the x and y coordinates. This holds true for both the "moving the entire grid" and "mesh deformation" options.
One possible explanation I can offer is that there's an interaction occurring between points, where some are primarily influenced by the fundamental frequency, while others are influenced by higher harmonics. However, if each point were solely influenced by a single frequency, it would have been easier for me to interpret the results.
I'm wondering if the presence of these higher harmonics might be due to factors such as nonlinearity, or numerical issues. For the majority of points in the simulation, the influence of higher harmonics (e.g., 3rd harmonics and beyond) appears to be negligible. Nevertheless, I'm curious about the underlying reasons for this behavior.
I'd greatly appreciate any insights or explanations you may have regarding this unexpected behavior.
Thank you!
Sigi is offline   Reply With Quote
dual time stepping in pitching airfoil simulation fluidmechanics SU2 Installation 1 August 30, 2018 09:00
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 06:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
