Home > Forums > Software User Forums > SU2
Output variable on a line.
Old   August 28, 2023, 05:33
Default Output variable on a line.
Zhang
Amber0922 is on a distinguished road
Hi, I'm running a 2D model recently. And I want to output the pressure of a line. The line is a boundary of the model, so I get " MARKER_PLOTTING = ( LINE )" , I think it will output what I need in the surface.csv, But to my surprise, it doesn't obtain the whole information what I need. So how can I output the pressure of the line of the model?
Amber0922 is offline   Reply With Quote
Old   August 28, 2023, 17:46
bigfoot
bigfootedrockmidget is on a distinguished road
What information do you see in the surface.csv?
It should be sufficient to use
MARKER_PLOTTING= ( wall )
VOLUME_OUTPUT=(SOLUTION)
OUTPUT_FILES= (SURFACE_CSV)
OUTPUT_WRT_FREQ= 10
Take a look for instance in the tutorials about the turbulent flat plate.
bigfootedrockmidget is offline   Reply With Quote
Old   August 30, 2023, 04:20
Zhang
Sorry, I made a stupid mistake. I overlooked that the ordering of SU2 is unit order, not abscissa. After reordering in horizontal order, everything is fine.
Thanks for your help. But for another question, if I want two surfaces information, how I distinguish them?
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 17:16
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
