August 14, 2023, 09:14 |
SU2 Mesh Generation from Gmsh
chang xu
Rep Power: 3 |
Hi everyone,
I am now trying generating a *.su2 file for aerodynamic calculations. But I keeps getting the error: Error in "void CPhysicalGeometry:istributeColoring(CConfig*, CGeometry*)": ------------------------------------------------------------------------- Mismatch between NPOIN and number of points listed in mesh file. Please check the mesh file for correctness. I have already turned off the saveall elements option during the exportation of .su2 file. Attached is the .geo file I am using. Can someone give me a hint of how to solve this problem? It would be much appriechiated. Best regards |
August 14, 2023, 16:19 |
bigfoot
Rep Power: 21 |
Did you inspect the su2 file and check that you have points and elements in the file? Mistakes during the setup can result in gmsh not writing the point coordinates or the element connectivity.
August 15, 2023, 08:02 |
chang xu
Rep Power: 3 |
thank you so much for your reply. I've checkey my su2 file, and there are no elements in the file And I have just found out that the problem is in my .geo file. The surface loop in the .geo file should include all the Surfaces in my case. And then define the physical surfaces. Thanks again for your help! Best regards |
August 21, 2023, 12:03 |
Giordana Bonavolontà
Hello I am having the same problem, could you please upload your corrected .geo file ?
Thanks |
August 22, 2023, 04:16 |
#5 | |
chang xu
Rep Power: 3 |
I have attached my .geo file in the attachment. My geo file is a very simple case for generating a farfield mesh around a predefined model. Hope this helps! Best regard |
August 22, 2023, 06:12 |
Hello and thanks, but I still have the same error in SU2 "Error in "void CPhysicalGeometry:istributeColoring(const CConfig*, CGeometry*)":
------------------------------------------------------------------------- Mismatch between NPOIN and number of points listed in mesh file. Please check the mesh file for correctness." Are you sure it worked for you in SU2 ? If yes, can you also please upload your SU2 cfg file ? regards |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 13:38 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[Gmsh] How to resolve gmsh 3D mesh generation errors | Mugen996 | OpenFOAM Meshing & Mesh Conversion | 0 | March 16, 2020 09:01 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
