Home > Forums > Software User Forums > SU2
Questions about the inlet/outlet boundary.
Old   July 23, 2023, 03:14
Default Questions about the inlet/outlet boundary.
Zhang
Amber0922 is on a distinguished road
Excuse me, I still have some questions about the boundary conditions.
Outlet: If I want a freestream outlet, in my opinion, the back pressure should be 0, but it didn't carry under 0. So can I get a freestream outlet as setting the back pressure as 1? Or should I set the outlet as farfield to get a freestream outlet?
Inlet: Also want a freesteam inlet. In Fluent, I usually set it as pressure-far-field, so is it the same as "MARKER_FAR" in SU2? Or set it as "MARKER_INLET"?
I'm sorry that my English is poor, so the statement of my question may be confusing. Thanks for your patience.
Amber0922 is offline   Reply With Quote
Old   September 15, 2023, 04:38
Zach Davis
RcktMan77 is on a distinguished road
Again, this depends on what type of flow you're simulating. For external flows, you typically set all of your outer boundaries to farfield type boundary conditions. For internal subsonic flows, you would typically set the upstream inflow boundary to a subsonic inflow boundary condition type where you specify total pressure and total temperature. For the downstream outflow boundary, you would set it to a subsonic outflow boundary type where you prescribe static pressure (or mass flow rate).
RcktMan77 is offline   Reply With Quote
Old   September 20, 2023, 03:03
Guangjing JU
Tomjugj is on a distinguished road
I also have questions about the outlet BC in SU2. For the SWBLI case in V&V in the official site[https://su2code.github.io/vandv/swbli/], the flow is supersonic at the outlet, why the cfg file specify the outlet pressure[https://github.com/su2code/SU2/blob/.../config_sa.cfg]? Usually, the flow downstream at supersonic speed is calculated from upstream, but SU2 does not provide such supersonic outlet boundary condition. In Wind-US configuration file, they specify the downstream pressure to be extrapolated, rather than specify the outlet pressure for the Ma=5 SWBLI hypersonic flow.[https://www.grc.nasa.gov/WWW/wind/va...y02/uns_sa.dat]
Tomjugj is offline   Reply With Quote
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
a couple of Inlet boundary condition questions Jochen Main CFD Forum 0 September 16, 2013 11:23
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
