Home > Forums > Software User Forums > SU2
Report bugs on discrete adj solver computation
Old   October 11, 2021, 09:18
Post Report bugs on discrete adj solver computation
HuiLi
1qaz!QAZ is on a distinguished road
RuntimeError: Path = /home/huili17/SOF-HL/3dtip/,
Command = mpirun -n 26 /usr/local/bin/SU2_CFD_AD config_CFD_AD.cfg
SU2 process returned error '137'
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 13 with PID 0 on node node5 exited on signal 9 (Killed).
hi all!
I met a problem on discrete adj solver, as shown on above.
I found it's related to the memory of the computing node. Is there any way to reduce the computing memory?
Thanks a lot!
1qaz!QAZ is offline   Reply With Quote
Old   October 12, 2021, 07:03
pcg
Pedro Gomes
pcg is on a distinguished road
Post your config
pcg is offline   Reply With Quote
Old   October 12, 2021, 10:21
HuiLi
Originally Posted by pcg View Post
Post your config
% SU2 configuration file %
% Case description: Multi-objective optimization for outflow averaged pressure %
% and a quadratic penalty function on a surface drag constraint, using %
% combined evaluation of the gradient rather than separate gradient %
% evaluations for each function. %
% For the definition of the penalty function see 'obj_p' method defined in %
% SU2/SU2_PY/SU2/eval/designs.py %
% Author: H.L. Kline, modified from inviscid wedge by Thomas D. Economon %
% Institution: Stanford University %
% Date: 2018.01.07 %
% File Version 4.0.1 "Cardinal" %
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% Physical governing equations (EULER, NAVIER_STOKES,
% TNE2_EULER, TNE2_NAVIER_STOKES,
% WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,
% POISSON_EQUATION)
SOLVER= RANS
KIND_TURB_MODEL= SA
% Mathematical problem (DIRECT, CONTINUOUS_ADJOINT, DISCRETE_ADJOINT)
MATH_PROBLEM= DIRECT
% Restart solution (NO, YES)
RESTART_SOL= YES
SYSTEM_MEASUREMENTS= SI
% Number of Zones
%NZONES= 1
% ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------%
% Mach number (non-dimensional, based on the free-stream values)
MACH_NUMBER= 0.0893
% Angle of attack (degrees)
AOA= 0.0
% Side-slip angle (degrees)
SIDESLIP_ANGLE= 0.0
% Init option to choose between Reynolds (default) or thermodynamics quantities
% for initializing the solution (REYNOLDS, TD_CONDITIONS)
INIT_OPTION= TD_CONDITIONS
% Free-stream option to choose between density and temperature (default) for
% initializing the solution (TEMPERATURE_FS, DENSITY_FS)
FREESTREAM_OPTION= TEMPERATURE_FS
% Free-stream pressure (101325.0 N/m^2 by default, only Euler flows)
FREESTREAM_PRESSURE= 103418.0
% Free-stream temperature (288.15 K by default)
FREESTREAM_TEMPERATURE= 278
%REYNOLDS_NUMBER = 1.6E5
%REYNOLDS_LENGTH = 0.091
% ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------%
% Fluid model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS,
% CONSTANT_DENSITY, INC_IDEAL_GAS, INC_IDEAL_GAS_POLY)
FLUID_MODEL= IDEAL_GAS
% Ratio of specific heats (1.4 default and the value is hardcoded
% for the model STANDARD_AIR, compressible only)
GAMMA_VALUE= 1.4
% Specific gas constant (287.058 J/kg*K default and this value is hardcoded
GAS_CONSTANT= 287.058
% Critical Temperature (131.00 K by default)
CRITICAL_TEMPERATURE= 131.00
% Critical Pressure (3588550.0 N/m^2 by default)
CRITICAL_PRESSURE= 3588550.0
% Acentric factor (0.035 (air))
ACENTRIC_FACTOR= 0.035
% --------------------------- VISCOSITY MODEL ---------------------------------%
% Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY, POLYNOMIAL_VISCOSITY).
VISCOSITY_MODEL= SUTHERLAND
% Molecular Viscosity that would be constant (1.716E-5 by default)
%MU_REF= 1.716E-5
%MU_T_REF=273.15
%SUTHERLAND_CONSTANT= 110.4
% --------------------------- THERMAL CONDUCTIVITY MODEL ----------------------%
% Conductivity model (CONSTANT_CONDUCTIVITY, CONSTANT_PRANDTL).
CONDUCTIVITY_MODEL= CONSTANT_PRANDTL
% Laminar Prandtl number (0.72 (air), only for CONSTANT_PRANDTL)
PRANDTL_LAM= 0.72
% Turbulent Prandtl number (0.9 (air), only for CONSTANT_PRANDTL)
PRANDTL_TURB= 0.90
% Compressible flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE,
% FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE)
%%%REF_DIMENSIONALIZATION= FREESTREAM_VEL_EQ_ONE
REF_DIMENSIONALIZATION= DIMENSIONAL
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Euler wall boundary marker(s) (NONE = no marker)
MARKER_HEATFLUX= ( shroud, 0.0, blade, 0.0, hub, 0.0 )
MARKER_PERIODIC= ( per1, per2, 0.0,0.0,0.0, 0.0,0.0,0.0, 0.0, 0.09135,0.0)
% Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW)
INLET_TYPE= TOTAL_CONDITIONS
% Inlet boundary marker(s) (NONE = no marker)
% Format: ( inlet marker, total temperature, total pressure, flow_direction_x,
% flow_direction_y, flow_direction_z, ... ) where flow_direction is
% a unit vector.
% Default: Mach ~ 0.1
MARKER_INLET= ( inlet, 278, 103418.6, 0.0, 0.555267, 0.831667 )
% Outlet boundary marker(s) (NONE = no marker)
% Format: ( outlet marker, back pressure (static), ... )
MARKER_OUTLET= ( outlet, 101324.6 )
% Marker(s) of the surface to be plotted or designed
MARKER_PLOTTING= ( blade)
MARKER_MONITORING= (outlet)
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
% Numerical method for spatial gradients (GREEN_GAUSS, LEAST_SQUARES,
% WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= GREEN_GAUSS
% Courant-Friedrichs-Lewy condition of the finest grid
CFL_NUMBER= 20.0
% Adaptive CFL number (NO, YES)
CFL_ADAPT= YES
% Parameters of the adaptive CFL number (factor down, factor up, CFL min value,
% CFL max value )
CFL_ADAPT_PARAM= ( 0.5, 2.0, 10, 1000.0 )
% Runge-Kutta alpha coefficients
RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 )
% Number of total iterations
ITER=10000
% Linear solver for the implicit formulation (BCGSTAB, FGMRES)
LINEAR_SOLVER= FGMRES
% Min error of the linear solver for the implicit formulation
LINEAR_SOLVER_ERROR= 1E-6
% Max number of iterations of the linear solver for the implicit formulation
LINEAR_SOLVER_ITER= 15
% Preconditioner of the Krylov linear solver (ILU, LU_SGS, LINELET, JACOBI)
LINEAR_SOLVER_PREC= ILU
% Linael solver ILU preconditioner fill-in level (1 by default)
%LINEAR_SOLVER_ILU_FILL_IN= 0
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
% Multi-Grid Levels (0 = no multi-grid)
MGLEVEL= 0
% Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE)
MGCYCLE= V_CYCLE
% Multi-grid pre-smoothing level
MG_PRE_SMOOTH= ( 1, 1, 1, 1 )
% Multi-grid post-smoothing level
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
% Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= 0.7
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= 0.7
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC,
% TURKEL_PREC, MSW)
CONV_NUM_METHOD_FLOW= JST
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations.
% Required for 2nd order upwind schemes (NO, YES)
MUSCL_FLOW= YES
% Slope limiter (VENKATAKRISHNAN, MINMOD)
SLOPE_LIMITER_FLOW= NONE
% Coefficient for the limiter (smooth regions)
VENKAT_LIMITER_COEFF= 0.1
% 2nd and 4th order artificial dissipation coefficients
JST_SENSOR_COEFF= ( 0.5, 0.02 )
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= EULER_IMPLICIT
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
% Convective numerical method (SCALAR_UPWIND)
CONV_NUM_METHOD_TURB= SCALAR_UPWIND
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations.
MUSCL_TURB= NO
SLOPE_LIMITER_TURB= VENKATAKRISHNAN
% Time discretization (EULER_IMPLICIT)
TIME_DISCRE_TURB= EULER_IMPLICIT
% ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, ROE)
CONV_NUM_METHOD_ADJFLOW= JST
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the adjoint flow equations.
MUSCL_ADJFLOW= YES
% Slope limiter (NONE, VENKATAKRISHNAN, BARTH_JESPERSEN, VAN_ALBADA_EDGE,
% SHARP_EDGES, WALL_DISTANCE)
SLOPE_LIMITER_ADJFLOW= VENKATAKRISHNAN
% 2nd, and 4th order artificial dissipation coefficients
ADJ_JST_SENSOR_COEFF= ( 0.5, 0.02 )
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT)
TIME_DISCRE_ADJFLOW= EULER_IMPLICIT
% Relaxation coefficient
RELAXATION_FACTOR_ADJOINT= 1.0
% Reduction factor of the CFL coefficient in the adjoint problem
CFL_REDUCTION_ADJFLOW= 0.8
% Limit value for the adjoint variable
LIMIT_ADJFLOW= 1E15
% Multigrid adjoint problem (NO, YES)
MG_ADJFLOW= NO
% Objective function in gradient evaluation (DRAG, LIFT, SIDEFORCE, MOMENT_X,
% MOMENT_Y, MOMENT_Z, EFFICIENCY,
% EQUIVALENT_AREA, NEARFIELD_PRESSURE,
% FORCE_X, FORCE_Y, FORCE_Z, THRUST,
% TORQUE, FREE_SURFACE, TOTAL_HEATFLUX,
% MAXIMUM_HEATFLUX, INVERSE_DESIGN_PRESSURE,
% INVERSE_DESIGN_HEATFLUX, SURFACE_TOTAL_PRESSURE,
% SURFACE_MASSFLOW)
% For a weighted sum of objectives: separate by commas, add OBJECTIVE_WEIGHT and MARKER_MONITORING in matching order.
OBJECTIVE_FUNCTION = SURFACE_TOTAL_PRESSURE
% List of weighting values when using more than one OBJECTIVE_FUNCTION. Separate by commas and match with MARKER_MONITORING.
OBJECTIVE_WEIGHT= 1.0
% Marker on which to track one-dimensionalized quantities
MARKER_ANALYZE = (outlet)
% Method to compute the average value in MARKER_ANALYZE (AREA, MASSFLUX).
MARKER_ANALYZE_AVERAGE = MASSFLUX
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Convergence criteria (CAUCHY, RESIDUAL)
CONV_FIELD= RMS_DENSITY RMS_MOMENTUM-X RMS_ENERGY RMS_ADJ_DENSITY RMS_ADJ_MOMENTUM-X RMS_ADJ_ENERGY
% Min value of the residual (log10 of the residual)
CONV_RESIDUAL_MINVAL= -20
% Start convergence criteria at iteration number
CONV_STARTITER= 20
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
% Mesh input file
MESH_FILENAME= mesh.su2
% Mesh input file format (SU2, CGNS, NETCDF_ASCII)
MESH_FORMAT= SU2
% Mesh output file
MESH_OUT_FILENAME= mesh_out.su2
% Restart flow input file
SOLUTION_FILENAME= solution_flow.dat
% Restart adjoint input file
SOLUTION_ADJ_FILENAME= solution_adj.dat
% Output tabular format (CSV, TECPLOT)
TABULAR_FORMAT= TECPLOT
% Output file convergence history (w/o extension)
CONV_FILENAME= history
HISTORY_OUTPUT= (ITER, RMS_RES, RMS_RES_ADJ)
% Output file restart flow
RESTART_FILENAME= restart_flow.dat
% Output file restart adjoint
RESTART_ADJ_FILENAME= restart_adj.dat
% Output file flow (w/o extension) variables
VOLUME_FILENAME= flow
% Output file adjoint (w/o extension) variables
VOLUME_ADJ_FILENAME= adjoint
% Output objective function gradient (using continuous adjoint)
GRAD_OBJFUNC_FILENAME= of_grad.dat
% Output file surface flow coefficient (w/o extension)
SURFACE_FILENAME= surface_flow
% Output file surface adjoint coefficient (w/o extension)
SURFACE_ADJ_FILENAME= surface_adjoint
% Read binary restart files
READ_BINARY_RESTART = YES
% Screen output
SCREEN_OUTPUT= (INNER_ITER, RMS_ADJ_DENSITY, RMS_ADJ_ENERGY, SENS_GEO, RMS_DENSITY, RMS_ENERGY, AVG_CFL, SURFACE_STATIC_TEMPERATURE)
OUTPUT_FILES= (RESTART, TECPLOT, SURFACE_TECPLOT, SURFACE_CSV)
% -------------------- FREE-FORM DEFORMATION PARAMETERS -----------------------%
% Tolerance of the Free-Form Deformation point inversion
FFD_TOLERANCE= 1E-10
% Maximum number of iterations in the Free-Form Deformation point inversion
FFD_ITERATIONS= 2000
% FFD box definition: 3D case (FFD_BoxTag, X1, Y1, Z1, X2, Y2, Z2, X3, Y3, Z3, X4, Y4, Z4,
% X5, Y5, Z5, X6, Y6, Z6, X7, Y7, Z7, X8, Y8, Z8)
% 2D case (FFD_BoxTag, X1, Y1, 0.0, X2, Y2, 0.0, X3, Y3, 0.0, X4, Y4, 0.0,
% 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
FFD_DEFINITION= (MAIN_BOX, -0.001, -0.05527, 0.2123, 0.119, -0.05527, 0.2123, 0.119, 0.02569, 0.2123, -0.001, 0.02569, 0.2123, -0.001, -0.05527, 0.30926, 0.119, -0.05527, 0.30926, 0.119, 0.02569, 0.30926, -0.001, 0.02569, 0.30926)
% FFD box degree: 3D case (x_degree, y_degree, z_degree)
% 2D case (x_degree, y_degree, 0)
FFD_DEGREE= (1, 20,20)
% Surface continuity at the intersection with the FFD (1ST_DERIVATIVE, 2ND_DERIVATIVE)
FFD_CONTINUITY= 2ND_DERIVATIVE
% ----------------------- DESIGN VARIABLE PARAMETERS --------------------------%
% Kind of deformation (FFD_SETTING, FFD_CONTROL_POINT_2D, FFD_CAMBER_2D, FFD_THICKNESS_2D,
% HICKS_HENNE, COSINE_BUMP, PARABOLIC,
% NACA_4DIGITS, DISPLACEMENT, ROTATION, FFD_CONTROL_POINT,
% FFD_DIHEDRAL_ANGLE, FFD_TWIST_ANGLE, FFD_ROTATION,
% FFD_CAMBER, FFD_THICKNESS, FFD_CONTROL_SURFACE, SURFACE_FILE, AIRFOIL)
%%DV_KIND= FFD_SETTING
% Marker of the surface in which we are going apply the shape deformation
%%DV_MARKER= ( blade )
% Parameters of the shape deformation
% - FFD_CONTROL_POINT ( FFD_BoxTag, i_Ind, j_Ind, k_Ind, x_Disp, y_Disp, z_Disp )
% - FFD_DIHEDRAL_ANGLE ( FFD_BoxTag, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End )
% - FFD_TWIST_ANGLE ( FFD_BoxTag, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End )
% - FFD_ROTATION ( FFD_BoxTag, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End )
% - FFD_CAMBER ( FFD_BoxTag, i_Ind, j_Ind )
% - FFD_THICKNESS ( FFD_BoxTag, i_Ind, j_Ind )
% - FFD_VOLUME ( FFD_BoxTag, i_Ind, j_Ind )
%%DV_PARAM= ( MAIN_BOX, 1, 0, 0, 0.0, 0.0, 1.0 )
% New value of the shape deformation
%%DV_VALUE= 0.0
% ------------------------ GRID DEFORMATION PARAMETERS ------------------------%
% Kind of deformation (FFD_SETTING, HICKS_HENNE, HICKS_HENNE_NORMAL, PARABOLIC,
% HICKS_HENNE_SHOCK, NACA_4DIGITS, DISPLACEMENT, ROTATION,
% FFD_CONTROL_POINT, FFD_DIHEDRAL_ANGLE, FFD_TWIST_ANGLE,
% FFD_ROTATION)
DV_MARKER= (blade)
DV_KIND= FFD_CONTROL_POINT
% - HICKS_HENNE_FAMILY ( Lower(0)/Upper(1) side, x_Loc )
% - NACA_4DIGITS ( 1st digit, 2nd digit, 3rd and 4th digit )
% - PARABOLIC ( 1st digit, 2nd and 3rd digit )
% - DISPLACEMENT ( x_Disp, y_Disp, z_Disp )
% - ROTATION ( x_Orig, y_Orig, z_Orig, x_End, y_End, z_End )
DV_PARAM= (MAIN_BOX, 3, 0, 0, 1.0, 0.0, 0.0 )
% Value of the shape deformation deformation
%DV_VALUE= 0.005
DV_VALUE= 1
% Number of smoothing iterations for FEA mesh deformation
%%DEFORM_LINEAR_SOLVER= FGMRES
DEFORM_LINEAR_SOLVER_ITER= 1000
% Number of nonlinear deformation iterations (surface deformation increments)
DEFORM_NONLINEAR_ITER= 1
% Print the residuals during mesh deformation to the console (YES, NO)
DEFORM_CONSOLE_OUTPUT= YES
% Minimum residual criteria for the linear solver convergence of grid deformation
DEFORM_LINEAR_SOLVER_ERROR= 1E-14
% Type of element stiffness imposed for FEA mesh deformation (INVERSE_VOLUME,
% WALL_DISTANCE, CONSTANT_STIFFNESS)
DEFORM_STIFFNESS_TYPE= WALL_DISTANCE
New obj func in discrete adjoint solver Zhen ZHANG SU2 1 August 2, 2021 00:17
Discrete Adjoint derivative computation - help understanding Finite Difference topheruk29 Main CFD Forum 0 July 21, 2021 07:54
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Report > Discrete Phase > Report > How to commands Francesco Micchetti FLUENT 1 January 23, 2008 07:10
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
