Home > Forums > Software User Forums > SU2
SU2 GUI version (Edu) available in Google Chrome Web Store
Old   July 13, 2016, 21:25
Default SU2 GUI version (Edu) available in Google Chrome Web Store
Data C
LetsCFD is on a distinguished road
Some people expressed an interest in SU2 GUI version in a YouTube presentation made by the SU2 team.
Now it is available in the Chrome Web Store as a free app. Click here if you are interested in it. If you don't want to use the Chrome Web Store, you can also access the app directly here.
So, it is better than a desktop GUI version. No compiling, no installation, and no third party viewers such as ParaView are needed. But you do need two things to run the app.
1. The latest Google Chrome Browser
2. A little appreciation for those Americans who invented the Internet:-)
LetsCFD is offline   Reply With Quote
Old   July 15, 2016, 03:45
Disabled
anon_k is on a distinguished road
Not a bad first attempt. The biggest thing I see missing is the output of Cl, Cd, and Cm. It would also be good if you explained each input. Ideally, what I would really like is the ability to do sweeps from 0 to 90 degrees. Having plots of Cl, Cd, and Cm. The software would have to adjust all of it's inputs depending on angle of attack to arrive at a solution. I am not sure at what AoA SU2 will fail to solve. That would be an additional challenge to overcome. As inputs, from a user point of view, I would only want to have to specify altitude, airfoil, and AoA range. All other inputs to the code being done behind the scenes and automatically.
anon_k is offline   Reply With Quote
Old   January 10, 2019, 09:18
N/A
lgn_aero is on a distinguished road
Good Work but needs lot of improvements.
Minimum cl, cd, cm and cp are worth to add.
lgn_aero is offline   Reply With Quote
chrome web store, su2 gui, web app
"reactingParcelFoam" active gravity, high courant number bijan darbari OpenFOAM Running, Solving & CFD 7 May 25, 2022 15:52
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 03:54
compressible low speed channel flow -Ali OpenFOAM Running, Solving & CFD 11 May 9, 2013 08:40
bubbleFoam validation case balkrishna OpenFOAM Running, Solving & CFD 24 August 30, 2010 05:37
