July 16, 2015, 17:08 |
Rotating RANS
Ryan Barrett
Rep Power: 11 |
I am attempting to use RANS with a SA turbulence model to analyze an airfoil with a rotating frame. Every time that I add the motion to my config file, it fails. All the examples in the test cases use Euler when rotating. Does SU2 have the capability to do a rotating frame with RANS? If so what parameters need to be defined for that to work? Thanks! |
September 15, 2015, 17:25 |
David Manosalvas-Kjono
Rep Power: 12 |
Ry10,
We have run rotating viscous airfoils successfully in the past, would you mind sharing with us the error message that you are getting? This will give us a better idea of what is going wrong and help us point you to the issue. David |
rans, rotating frame, su2 |
Rotating ZigZag Bed | Pugnax | CFX | 8 | March 8, 2015 18:16 |
ISSUES: Rotating VS Non-Rotaing Domains | gigiboumba | CFX | 3 | April 26, 2014 08:22 |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 09:53 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 04:14 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 07:14 |
