Problem with grid sensitive test cases(shock instability) in SU2.!!! |
November 5, 2014, 10:30 |
Vino
Rep Power: 13 |
Dear SU2 team,
I am trying some grid sensitive shock instability test cases with SU2 and I am not getting the expected results. I feel it may be due to the formation of dual cell from primal grid, which is changing the edge alignment and aspect ratio of the grid. But my simulations are very sensitive to grids and any small change in grid size or aspect ratio may results in wrong results. Is there any way to take the grid as it is what I give (i.e the primal grid)? Is it possible to convert the vertex based method to cell center based method? or Is there any way to form of solution which can help ti fix this issue? Thank you very much.!!! |
November 26, 2014, 21:16 |
Francisco Palacios
Rep Power: 15 |
Unfortunately it is not trivial but, if you have a Cartesian mesh, both formulation should be equivalent.
Cheers, Francisco |
November 27, 2014, 05:33 |
Vino
Rep Power: 13 |
how to define a shape deformation using the grid deformation variables (FSI problem) | momo_sjx | SU2 Shape Design | 6 | June 7, 2015 23:29 |
Which grid generator for SU2? | Chris Lee | SU2 | 3 | October 3, 2014 13:59 |
grid independence test in ansys14 fot fluent | abinashlipun | FLUENT | 1 | January 17, 2013 11:48 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 12:18 |
