June 26, 2014, 10:57 |
Real use case tutorial request
Hedley
Rep Power: 12 |
Many General Aviation pilots have a need to establish the lift distribution on the wings My foray into CFD has been to try and ascertain the lift distribution and then modify the wingtip 3D model - perhaps honer and outboard airfoil section to improve low speed handling and reduce induced drag . The second task is to look at the flow to determine the optimum position for stall strips on a laminar flow wing .
All of this happens between 70 KTS and 200 KTS. I have been told by test pilots and wind tunnel folk that CFD is a mathematical attempt to simulate nature and requires an excellent Mesh flow field before the solver can crunch the numbers . They recommend switching off the computer as in their opinion CFD near the stall and turbulent simulation and analysis is years off ? There advice is go and fly the plane with tufts and then rinse and repeat . Are there any plans to do an A-Z tutorial from the 3D model --> Mesh generation --> solver --> Paraview results and interpretation thereof. This would be a really useful resource to the community and could be used in university courses . Neophytes like me have cursory knowledge of the toolchain but know what we are trying to get out at the end . Often the experts assume a certain expertise level , which is understandable but a step by step tutorial which details the considerations and choices at each waypoint in the process would be great . I do apologize for all my posts but they are all aimed at achieving this end point . Yes Paraview has its own forum as does point-wise but I can not find the A-Z of a project from conception to interpretation of the output . connecting the dots in the toolchain is really challenging as most of the projects seem to be at high mach numbers . |
June 26, 2014, 16:24 |
The only thing that I can suggest you is reading the following book and making CFD-based simulation experiences for yourself. Other fellow might have any other useful suggestions, links, or lectures. http://link.springer.com/book/10.1007%2F3-540-32382-1 Good Luck, PDP |
June 26, 2014, 16:57 |
Trent Lukaczyk
Rep Power: 15 |
UDF for Turbulent Viscosity | Lourival | Fluent UDF and Scheme Programming | 3 | October 13, 2012 04:09 |
UDF error - FLUENT received fatal signal (ACCESS_VIOLATION) | Eliasjal | Fluent UDF and Scheme Programming | 1 | March 7, 2012 12:11 |
how to hook this udf | shanu | FLUENT | 1 | August 26, 2011 11:48 |
Request for pipe bifurcation fluent tutorial case | Giorgos Momferratos | FLUENT | 0 | October 20, 2008 16:10 |
udf error | Rashmi | FLUENT | 0 | December 27, 2005 06:35 |
