June 24, 2014, 11:43 |
Parameters Tuning when solving the adjoint
Tommy Chen
Rep Power: 15 |
Hi Guys. I have ran a wing-body case at mach 0.85, the flow converged well. However when I solved the adjoint, the res always diverged, I used the same settings as the steady M6 RANS optimization case. So anyone has experience on tuning the adjoint sovler parameters to handle this ?
June 24, 2014, 22:01 |
Thomas D. Economon
Rep Power: 14 |
Hi Tommy,
Have you tried to adjust the 4th order dissipation coefficient for the modified JST scheme when solving the adjoint? You can try to increase the dissipation to see if you get convergence. Possibly switch to the Roe scheme and activate the limiter. The typical strategies for converging the flow problem also apply... check that the CFL isn't too high and try turning off the multigrid too. Hope this helps, Tom |
June 26, 2014, 17:02 |
#3 | |
Tommy Chen
Rep Power: 15 |
Hi Tom: Is that OK if I solve the flow using JST but solve the adjoint using Roe ? |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
