Home > Forums > Software User Forums > SU2
Error when parallel
Like Tree1Likes
  • 1 Post By Doriris
Old   June 17, 2014, 05:44
Default Error when parallel
Antoni Alexander
zkdkeen is on a distinguished road
Hello everyone, I am a new SU2 user. After finishing parallel installation on a cluster, I run the m6 example which yields the following error:
$ parallel_computation.py -f inv_ONERAM6.cfg -p 4
Traceback ...
File "usr/local/bin/parallel_computation.py" line27
Import SU2
File "usr/local/bin/SU2/___init___.py" line 3
from . Import run
SyntaxError : invalid syntax
And I am sure that I have done the parallel config right. So, is there any other possible reason for this?
Any suggestion will be appreciated.
zkdkeen is offline   Reply With Quote
Old   June 17, 2014, 23:30
XingYu
454514566@qq.com is on a distinguished road
I install the V3.2 in win7,but when paralleling,facing an similar error:
D:\>cd naca0012
D:\naca0012>parallel_computation.py -f inv_NACA0012.cfg -p 2
Traceback (most recent call last):
File "C:\SU2\parallel_computation.py", line 26, in <module>
import SU2
ImportError: No module named SU2
D:\naca0012>
I am looking forward to your rely
454514566@qq.com is offline   Reply With Quote
Old   June 18, 2014, 06:33
Jeffrey van Oostrom
Doriris is on a distinguished road
Simply copy the folder "SU2" from the folder "SU2_PY/" from the source files to the folder where the parallel_computation.py is located.
Doriris is offline   Reply With Quote
Old   June 18, 2014, 07:12
XingYu
it is thesame as the before,I look the code,in the"parallel_computation.py"file:
import os, sys, shutil, copy
from optparse import OptionParser
sys.path.append(os.environ['SU2_RUN'])
import SU2
# Main
The error is coming the "import SU2",I want to know why the "import SU2" is here and why the error is ImportError: No module named SU2
After I install the SU2 V3.2,I set the "SU2_CFD" and "SU2_RUN" as the "path" in environment variable like V3.1,Do I need do something else?
Look forward to your reply.
Old   June 18, 2014, 08:49
Jeffrey van Oostrom
When I installed the 3.2 version, I went to C:\SU2 and it did not have any folders. The python script tries to import a folder called SU2, but it does not exist, nor are the require files present. What I did, was simply download the source code, and within that source code there is a folder called "SU2_PY". In that folder, there is a folder called "SU2", which is the folder that is missing in the windows installer. Copy that folder into your C:\SU2, such that there is a folder called SU2, including the file contents in folder C:\SU2.
To summarize:
Download the source code here:
https://github.com/su2code/SU2/archive/v3.2.0.zip
Copy the folder /SU2_PY/SU2 to C:\SU2
The folder C:\SU2 looks like:
2DChannel.py
3DChannel.py
change_version_number.py
compute_polar.py
compute_stability.py
config_gui.py
continuous_adjoint.py
documentation.txt
filter_adjoint.py
finite_differences.py
hdf5.dll
libiomp5md.dll
merge_solution.py
mesh_adaptation.py
mesh_deformation.py
package_structure.txt
package_tests.py
parse_config.py
patient_designspace.py
set_ffd_design_var.py
shape_optimization.py
SU2/
SU2_CFD.exe
SU2_DEF.exe
SU2_DOT.exe
SU2_GEO.exe
SU2_MSH.exe
SU2_PRT.exe
SU2_SOL.exe
szip.dll
tecio.dll
zlib.dll
Good luck!
vbaros likes this.
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 16:25
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 12:30
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
