Home > Forums > Software User Forums > SU2
External Axisymmetric Flow
Like Tree1Likes
  • 1 Post By copeland
Old   May 15, 2014, 09:03
Default External Axisymmetric Flow
Facundo
akun646 is on a distinguished road
Hello community!
I am new in SU2, I would like to do a simulation of a sphere in hypersonic regime to compare with those results obtained form a code developed by ourself. Is "Symmetry boundary marker" the boundary condition that I have to use for the axis of symmetry? I suppose so, but just want to be sure.
Thank you very much in advance!!!!
akun646 is offline   Reply With Quote
Old   May 15, 2014, 16:19
Sean R. Copeland
copeland is on a distinguished road
Hello akun646,
You have a few options for running axisymmetric cases with SU2.
1) You can run a 3-D simulation with two symmetry planes that intersect at the axis of symmetry. If you choose this approach, SU2 does not have the logic to detect the polar singularity, so be sure that any references to the polar singularity are removed in the mesh file and apply the symmetry boundary conditions to the two faces as normal.
2) You can run a 2-D axisymmetric simulation. If you choose this approach, provide a two-dimensional grid, and be sure that the AXISYMMETRIC tag is set to 'YES' in the configuration file. Then apply the symmetry boundary condition along the symmetry axis as normal.
Good luck!
-Sean
Originally Posted by akun646 View Post
Hello community!
akun646 likes this.
copeland is offline   Reply With Quote
Old   May 16, 2014, 04:06
Facundo
Hello Sean,
the idea is to start with a 2D axisymmetric model. Thank you very much for your help, it is truly helpful!!
Facundo
evaporator design including external flow coprem FLUENT 0 September 26, 2011 05:34
how can I Run axisymmetric flow using dsmcFoam ? mechy OpenFOAM 4 September 19, 2011 11:25
How do I select solver options for external flow over an aircraft by fluent? hadieliasi FLUENT 5 May 2, 2011 04:54
external flow meshing for a Sedan in pro*am rave Siemens 7 July 17, 2007 10:48
axisymmetric main flow + injection Stephan FLUENT 1 January 19, 2006 12:43
