April 10, 2014, 03:58 |
There is a catastropic failure in SU2 3.0.1
zhen yi
Rep Power: 12 |
Hello guys,
When I used SU2 3.0.1 to run some Testcases, there are some catastropic failure that almost all Testcases could not run. When I use SU2_CFD to run a serial case, there are some MPI error occurred below: WARNING: unrecognized option in the config. file: CONVERT_TO_METER. ERROR: Cannot find value NONE in given map. Please check the name of the variable in the config file. -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [isc01@login-0-0 oneram6]$ SU2_CFD inv_ONERAM6.cfg WARNING: unrecognized option in the config. file: CONVERT_TO_METER. ERROR: Cannot find value NO_DEFORMATION in given map. Please check the name of the variable in the config file. -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- May somebody could give some help? |
April 13, 2014, 19:42 |
Thomas Van Alsenoy
In my experience, some option names changed after the 3.0.1 release. You can find an example configuration file in your main SU2 folder called "config_template.cfg" or here Use this name convention in the old Testcase config files or create a new file based on the template with the right settings. Cheers |
SU2 3.0 build failure | waku2005 | SU2 Installation | 4 | January 24, 2014 13:40 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 06:28 |
SU2 suite has moved to GitHub! | fpalacios | SU2 News & Announcements | 0 | August 12, 2013 03:07 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 03:48 |
New SU2 Forum Opened at CFD Online | pete | Site News & Announcements | 0 | January 5, 2013 18:59 |
