Home > Forums > Software User Forums > SU2
Adding a force at a specific point.
Old   April 3, 2014, 00:44
Default Adding a force at a specific point.
cgusty01 is on a distinguished road
I am an engineering student and am new to SU2 and CFD in general. I am trying to add a surface force on an airfoil to simulate the suction of a plasma actuator. I want to be able to alter the velocity field at a specific point on the surface of the airfoil.
In order to do so, what files would I need to change? Is there a specific source file that would let me do something like this? I am lost.
Thank you for your help!
cgusty01 is offline   Reply With Quote
Old   April 3, 2014, 21:08
Francisco Palacios
fpalacios is on a distinguished road
Thanks for using SU2,
Are you running Euler or Navier-Stokes?
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   April 3, 2014, 21:22
Francisco,
I am using Euler.
Thank you,
Chris
Old   April 13, 2014, 16:04
Francisco Palacios
Francisco,
I am using Euler.
Thank you,
Chris
Thanks Chris,
As you know, the boundary condition for Euler problems is a slip boundary condition, so in practice it is not possible to modify the velocity (normal to the surface). In that case my recommendation is to use the inlet boundary condition
% Inlet boundary marker(s) with the following formats (NONE = no marker)
% Total Conditions: (inlet marker, total temp, total pressure, flow_direction_x,
% flow_direction_y, flow_direction_z, ... ) where flow_direction is
% a unit vector.
% Mass Flow: (inlet marker, density, velocity magnitude, flow_direction_x,
% a unit vector.
MARKER_INLET= ( NONE )
Another possibility is to use a Navier-Stokes solution, in that situation you can specify a velocity on the solid surface different from 0.
Best Regards,
Francisco
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 01:37
error message cuteapathy CFX 14 March 20, 2012 07:45
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
Overall picture versus specific point Nick Main CFD Forum 0 October 7, 2004 12:25
