Home > Forums > Software User Forums > SU2
Modify from Euler to NS, Do me a favor please
Old   March 18, 2014, 05:27
Default Modify from Euler to NS, Do me a favor please
JinZhiyi
JinZhiyi is on a distinguished road
Hi everyone,
I am using SU2 to simulate a standard aero-model rotating blade, the Euler simulation runs well, the simulated lifting force is only about 5% to the experimental data.
But I am really new to su2, i can not set up the configure file for N-S simulation . Can any nice guy do me a favor, modify the configure file please, really appreciate.
By the Way: the diameter of the blade is 30cm, it rotates at the angular speed of 3000RPM, so it should be low-Reynolds.
Also if you need grid file(in pointwise formate) or SU2 formate, please leave your e-mailbox .
Jin
JinZhiyi is offline   Reply With Quote
Old   March 20, 2014, 18:52
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Originally Posted by JinZhiyi View Post
Hi everyone,
Jin
Hi JinZhiyi,
See the modified file according to your specified operating conditions. Have a look at the comments related to Navier-Stokes settings.
I would like to have a look at the pointwise grid, if possible send me the link via private message or share it in the forum. Have fun and in case of problem just write on the forum.
Good luck.
taxalian is offline   Reply With Quote
Old   March 23, 2014, 05:47
JinZhiyi
Originally Posted by taxalian View Post
Hi JinZhiyi,
Good luck.
Dear Taxalian:
Thanks for your modification, I have uploaded my grid in Pointwise format, and geometry model in IGS format to ONEDRIVE. And I encounter an error when i ran your cfg file with my grid, please check it.
By the way, I made a mistake last time about the diameter of rotor, it should be 38cm, so the Reynolds number should be approximately 1.6E6.
https://onedrive.live.com/redir?resi...1C35D62C%21107
Thanks again
Jin
Old   March 23, 2014, 16:09
Dear Taxalian:
Thanks again
Jin
Dear Jin,
Thanks for providing the grid too. I ran your test case with your config file, the code complaints about the convective scheme that is not implemented. So i tested it with my standard SU2 v3.0 Eagle config file. The simulation runs without any problem except i did some modifications in the flow settings like the reference length, origin for moment based on the rotor diameter and least_square numerical scheme for gradients than the green_gauss. See the attached config file for further reference and adjust the flow parameters accordingly to your requirements.
Good luck.
Old   March 23, 2014, 23:12
JinZhiyi
Dear Jin,
Good luck.
Thank you Taxalian, did you forget to attach the renewed configure file, I can't see the attached file in your last reply.
Kind regards
Jin
Old   March 24, 2014, 11:09
Kind regards
Jin
Hi Jin,
there you go, see the attached file.
Best regards,
Taxalian
Old   March 27, 2014, 01:19
JinZhiyi
Hi Jin,
Best regards,
Taxalian
Hi Taxalian, now it works well, despite the result torque number is still far away from the experimental data, but I will try to tackle this problem, and figure out the right way.
Thank you so much again!
Best regards
Jin
Old   March 27, 2014, 12:35
Best regards
Jin
Hi Jin,
Good to know that its working, wish you good luck. In order to improve the torque number you can try a finer mesh + turbulence model effect i.e SST turbulence model.
Regards,
Taxalian
how to modify fvScheme to converge? immortality OpenFOAM Running, Solving & CFD 15 January 16, 2013 14:06
Problem with Backward Euler Results Hooman Main CFD Forum 5 January 1, 2012 12:02
euler model CN FLUENT 0 July 4, 2005 17:35
