Home > Forums > Software User Forums > SU2
segmentation fault
Old   November 2, 2013, 07:18
Default segmentation fault
wangjian
jwang1_09 is on a distinguished road
I have recently started using SU2 for my research work. I have the following question:
I used the pointwise software to generate a 2D mesh of SU2 format.But when I used the SU2 to compute the airfoil,it always appeared segmentation fault while it got to the solution preprocessing.How should I deal with the problem.
Thanks,
Mandar
jwang1_09 is offline   Reply With Quote
Old   November 3, 2013, 21:16
Francisco Palacios
fpalacios is on a distinguished road
Thanks,
Mandar
Could you please be more specific about the problem? SU2 version, config file, etc? Have you try the tutorials?
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   November 3, 2013, 22:01
wangjian
Best,
Francisco
Hello:
I am using the SU2v2.0 and the config file is the inv_NACA0012.cfg.I used pointwise software to build a unstructed mesh for NACA6412 airfoil and changed the boundary condition definition of config file to be consistent with the definition in the pointwise.However,when I used the SU2 to compute,it always appeared segmentation fault.
Thanks.
Old   December 12, 2013, 08:22
Mandar Kulkarni
kmandar is on a distinguished road
Thanks,
Mandar
wangjian,
I think in your post dated November 2, 2013, 07:18 you copy-pasted one of my messages along with my name!
Mandar Kulkarni
kmandar is offline   Reply With Quote
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 18:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 15:38
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 08:23
