Home > Forums > Software User Forums > SU2
Mesh deformation not converging with 'GRID_DEFORM_METHOD' as "FEA"
Old   October 9, 2013, 02:53
Default Mesh deformation not converging with 'GRID_DEFORM_METHOD' as "FEA"
Anant Diwakar
diwakaranant is on a distinguished road
Hi
I was trying to find the gradients for Onera M6 wing for rans case using
finite_differences.py using SU2 v 2.0.5
I am using "FEA" as grid deform method, but the mesh deformation doesn't
seem to converge when the mesh is deformed after each flow run.
HTML Code:
----------------- FFD technique (parametric -> cartesian) ---------------
Update cartesian coord        | FFD box: 0. Max diff: 1.46435e-07.
----------------------- Volumetric grid deformation ---------------------
Performing the deformation of the volumetric grid.
=> BCGSTAB residual history
=> residual tolerance target = 1e-08
=> initial residual norm     = 7.61365e+06
     0     3.20299e+12
     50     15819.9
     100     2367.66
     150     851.439
     200     613.143
     250     23395.4
     300     3507.32
# BCGSTAB final (true) residual:
# iteration = 300: |res|/|res0| = 3507.32
End and write output files.
------------------------- Exit Success (SU2_MDC) ------------------------
The mesh deformation code seems to run upto 300 iterations leading
to incomplete convergence.
Why is this happening ?
Thanks
Anant
diwakaranant is offline   Reply With Quote
Old   October 9, 2013, 18:09
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by diwakaranant View Post
Hi
HTML Code:
     0     3.20299e+12
     50     15819.9
     100     2367.66
     150     851.439
     200     613.143
     250     23395.4
     300     3507.32
Thanks
Anant
The current 3D implementation of the grid deformation is based on Tets (as a preprocessing the Hex are divided into Tets). This is not optimal, we are working in a real FEM implementation of the Hex element. But this going to take some time unless somebody in the open-source community helps us with this "easy" development.
Meanwhile, our recommendation is use Tets grids or perform small deformations and use the parameter.
LINEAR_SOLVER_ITER=10
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   October 11, 2013, 16:51
Thomas D. Economon
economon is on a distinguished road
I'll also pitch in and say that it may be worth trying with one of the newer versions of SU2, such as V2.0.8, as we have made a few improvements to the FEA since V2.0.5.
T
economon is offline   Reply With Quote
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
overflow and negative volume error in mesh deformation sakalido CFX 11 November 27, 2012 16:16
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
