Home > Forums > Software User Forums > SU2
Non-uniform inlet conditions?
Old   September 16, 2013, 12:38
Post Non-uniform inlet conditions?
Magnus W
winter is on a distinguished road
Hi everyone!
I was interested in validating SU2's incompressible solver to the Pitz Daily (backward facing step) experiment. To conduct the simulations it would be beneficial to use a profile for the velocity and the turbulence quantities (k and omega), as the entrance length is quite long.
I haven't, so far, found that SU2 is capable to use profiled inlet conditions. Has anybody found a way to use non-uniform inlet conditions in SU2?
winter is offline   Reply With Quote
Old   October 3, 2013, 15:18
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by winter View Post
Hi everyone!
Dear Magnus,
Thanks a lot for your interest in SU2. Most of the work in SU2 has been done for external flows, and so far we don't have a method to introduce an inlet profile.
However, it is not complicate to add this capability, and we are looking forward for contributions. A good starting point would be to modify.
void CEulerSolver::BC_Inlet(CGeometry *geometry, CSolver **solver_container, CNumerics *conv_numerics, CNumerics *visc_numerics, CConfig *config, unsigned short val_marker)
in solver_direct_mean.cpp and instead of using the velocity at the Infinity (GetVelocity_Inf) create a function that reads the velocity profile from a file and interpolate the solution given a (X,YZ) coordinate geometry->node[iPoint]->GetCoord().
As you can see, SU2 use the weak formulation, so a numerical flux will be computed between the value that you provide and the actual value at the node, and then the result will be added to the total residual at the point.
Our recommendation is to fork the SU2 repository in https://github.com/su2code and contact us if you need further support.
Thanks again for your interest,
Francisco
fpalacios is offline   Reply With Quote
Channel flow using InterFOAM DanM OpenFOAM Running, Solving & CFD 49 July 31, 2020 12:43
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC mgdenno OpenFOAM Community Contributions 4 July 1, 2012 09:16
chtMultiRegionSimpleFoam javad814 OpenFOAM 1 September 26, 2011 14:30
