Home > Forums > Software User Forums > SU2
job aborted when come to write solution file
Old   June 11, 2013, 22:50
Default job aborted when come to write solution file
cean wang
ceanwang is on a distinguished road
I just compiled 2.0.4 against MPICH2 on win7@32 with gcc for win.
When trying the Euler/naca0012 case with 8 cores, the program stopped when it needs to write solution file.
I set:
% Writing solution file frequency
WRT_SOL_FREQ= 100
After 100 Iter, the error mes is like this:
job aborted:
rank: node: exit code[: error message]
0: pcname: -1073741819: process 0 exited without calling finalize
1: ...AS ABOVE
7: ...
if I set WRT_SOL_FREQ= 50, it will aborted after 50 Iters.
Any suggestion?
Regards,
Cean
ceanwang is offline   Reply With Quote
Old   June 28, 2013, 20:23
Thomas D. Economon
economon is on a distinguished road
Hi Cean,
Not sure if it will address your current issue, but could you please try again with version 2.0.5? We made some changes to the solution output routines, in general. If not, it may be a platform specific issue.
Cheers,
Tom
economon is offline   Reply With Quote
Old   June 28, 2013, 22:05
Cean
shirazbj is on a distinguished road
Originally Posted by economon View Post
Hi Cean,
Cheers,
Tom
Hi Tom,
I traced to the line which can't run and added one output line. Then it has no problem now.
Sometimes the compiler is strange.
Regards,
Cean
shirazbj is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] problem on installing swak4Foam navid2 OpenFOAM Community Contributions 2 May 30, 2012 05:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
