November 30, 2009, 12:27 |
Problem of smearing vof air-liquid
davide
I have a problem with the following simulation. I have two cylinder that round with the same tangencial speed. There is a gap of 1 [mm] between the two cylinder and the second is complety immersed in liquid. The first cylinder is immersed for few mm and put the fluid in vertical position. The problem is that I see for the cylinder immersed a smeraing of fluid during rotating. The dimension of cell is 0.6 [mm] I considered surface tension, gravity, k-epsilon model, 10 iteration every time step, and time step I set of 1e-04 [s].
I accept some conseil to resolve these problem than you very much |
vof smearing liquid gas |
mass conservation problem with VOF model | pat77 | FLUENT | 6 | February 24, 2017 05:39 |
VOF problem, liquid film thickness | Pedro24 | FLUENT | 0 | May 13, 2009 06:57 |
Problem with VOF | Jiri Novak | FLUENT | 1 | March 17, 2006 06:13 |
The problem of modeling free jet with VOF | river | FLUENT | 0 | December 27, 2005 03:29 |
can we Simulate air bubble inside hot liquid | Mohan | FLUENT | 0 | December 15, 2005 15:22 |
