Why the moving reference frames can be used for unsteady simulation? |
Rinia
Rep Power: 8 ![]() |
Hey,
I performed a simulation in SATR CCM+ with the Moving Reference Frames, and found that the simulation can be solved by the unsteady simulation? In official tutorials, the moving reference frames is only used for steady simulation. Anyone could explain the difference between using unsteady and steady solver? |
Rep Power: 16 ![]() |
MRF is, in the classical understanding, an approach for steady-state simulations. In STAR-CCM+, you can combine MRF with an unsteady simulation, but its not time-accurate. So it doesn't make too much sense, actually. But it can still be a compromise, depending on the focus of our investigation. Theoretically, the only "real" unsteady simulation would be if you realize the rotation via rigid body motion or using overset. |
[OpenFOAM.org] Not found many .so files when installing OpenFOAM 6 | lengjun | OpenFOAM Installation | 2 | December 12, 2022 23:08 |
[OpenFOAM.com] An Error in recompiling of openFoam-4.0 | alimea | OpenFOAM Installation | 4 | April 8, 2020 15:44 |
can not complie fluentDataToFoam in OF2.1.1 | hewei | OpenFOAM Pre-Processing | 20 | September 8, 2018 10:19 |
Error in compiling new drag model | k.farnagh | OpenFOAM Programming & Development | 13 | May 21, 2016 04:08 |
Moving Reference Frames. | J Foster | Main CFD Forum | 5 | August 21, 2001 02:13 |
