October 31, 2018, 08:21 |
Postprocessing STAR-CCM+ results in ParaView
phil
Rep Power: 8 |
I want to visualize the results of my 3D-CFD STAR-CCM+ calculation with ParaView. I need to use ParaView because I want to use plugins form the Heidelberg University for detecting vortex cores. I installed ParaView from the university homepage, because this already includes the plugin which I want to use. Now, my problem. I export my results in STAR-CCM+ as .case-Files. Afterwards I open the .case-File in ParaView. There I can only see the grid data and no numerical data. Where is my mistake? Thank you, Philipp |
October 31, 2018, 13:41 |
Rep Power: 25 |
When you exported the .case files, did you choose which scalars/vectors you wanted to export on the regions you wanted?
February 28, 2019, 10:54 |
#3 | |
Rep Power: 10 |
How to see a Star CCM+ Simulation with Paraview? |
ccm+, paraview, plugins |
Different results with postChannel and ParaView | Ria | OpenFOAM Post-Processing | 1 | August 5, 2014 07:59 |
[OpenFOAM] run paraFoam command results in error: line 267: paraview: command not found. | Asik | ParaView | 1 | December 25, 2013 12:45 |
Star CCM 8.02 compatible version of Netbeans | trsakthipriya | STAR-CCM+ | 2 | July 10, 2013 06:14 |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 23:15 |
Exporting results from Star to Ensight | AJK | Siemens | 1 | February 8, 2006 04:53 |
