Import solution from another simulation
Like Tree2Likes
  • 2 Post By Ubuntu
Old   September 7, 2018, 08:37
Default Import solution from another simulation
Soonseok Soong
sssong0409@gmail.com is on a distinguished road
Hi, I am trying to plot a pressure difference of two simulations on the body in a 3D scene. (two simulations using the same mesh, but different conditions hence different pressure distributions)
I tried to import the solution and subtract the pressure fields, but I couldn't as they are in different regions (original region and imported region).
And, I tried to map the field function of the imported region (pressure) into the original region, but there is an error ("INPUT ERROR: Choose source fields for mapping.")
Does anyone know how to do it or any tutorials?
Thank you
sssong0409@gmail.com is offline   Reply With Quote
Old   September 9, 2018, 00:12
Smile A suggestion!
Ubuntu's Avatar
Siddharth
Ubuntu is on a distinguished road
Hi Soonseok,
Say you have simulations Sim1 and Sim2 with same mesh but different conditions. Try the following.
1. Export the 'solution data only' from Sim1. (select your desired functions) Say, Sim1_sol.
2. Export the 'mesh data only' from Sim2. Say, Sim2_mesh.
3. Import Sim1_sol to Sim2.
4. You will see new field functions generated in Sim2.
5. Write one field function to find the difference (like $newPressure-$Pressure)
6. Create a scalar scene with your field function.
Hope this helps!
Ubuntu is offline   Reply With Quote
Old   September 10, 2018, 07:19
Smile
Soonseok Soong
Originally Posted by Ubuntu View Post
Hi Soonseok,
Hope this helps!
Thank you very much for your reply, I have solve the problem with another solution though.
The problem was I cannot subtract the field functions because they were in different regions, that is why I was trying to map the field function into another region (imported region to original region).
When I tried to map the solution using 'right click' in the imported part tree, I couldn't do this for an error I don't understand, but when I tried the same thing at 'Tools-Data Mappers' I could manage to do this. (I don't know what is the difference between two as I put the same input part, target part, target field function, etc.)
Thank you.
Old   September 10, 2018, 07:48
Thumbs up
Ubuntu's Avatar
Siddharth
Glad to hear that your problem is solved
Old   May 29, 2020, 10:34
Abhishek Shingala
Abhishek Shingala is on a distinguished road
Hi Soonseok,
Hope this helps!
How can I import solution data (Sim1_sol)? and what is the use of mesh which is exported from sim2(Sim2_mesh)?
Abhishek Shingala is offline   Reply With Quote
Old   September 7, 2020, 16:27
Xutong
zhxutong is on a distinguished road
Import -> Import Volume Mesh
zhxutong is offline   Reply With Quote
data maaping, import solution
Using solution of a complete simulation in order to simulate just an extract bench_ STAR-CCM+ 0 December 12, 2017 13:06
[General] Plotting solution vector from Matlab in Paraview crg123 ParaView 0 November 20, 2016 13:19
Unsteady simulation with steady solution as initial value kiddmax OpenFOAM Running, Solving & CFD 8 August 20, 2015 06:12
Zero mass flow rate and non converging solution during fan simulation Bisht STAR-CCM+ 6 June 4, 2015 10:20
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
