Flow Angle Specification
Old   June 13, 2018, 09:23
Default Flow Angle Specification
kn008
Nikhil008 is on a distinguished road
Hello all,
I am using STAR CCM+ V12.06. I want to specify some angle to my flow. I selected mass flow inlet as inlet and selected angle in flow specification. I need to assign phi, theta and psi angle for angular flow. Can anyone specify what these angles are and how to specify them
Nikhil008 is offline   Reply With Quote
Old   June 13, 2018, 10:00
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Originally Posted by Nikhil008 View Post
Hello all,
In physics conditions node, change the flow direction specifications to components. Then create a cylindrical co-ordinate system in tools node with Z-axis along the flow direction you want to give. Then in physics values node, in flow direction node, change the co-ordinate system to this cylindrical co-ordinate system. Remember Z is your axial direction (X-radial, Y-tangential). For flow direction node, change it from constant to composite. Then give X,Y,Z values there. Try this on some simple pipe and observe the swirl using streamlines. Then use this in actual case. Hope this helps.
ashokac7 is offline   Reply With Quote
angle specification, mass flow inlet confusion
Flow angle distribution RPFigueiredo CFX 8 April 23, 2013 08:31
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Mass Flow Inlet with Velocity specification bernarde STAR-CCM+ 1 December 4, 2009 00:13
angle for wall adhesion in two phase flow Al-jasim FLUENT 0 August 18, 2007 11:04
Modelling flow over airfoil at near stall angle Kelvin FLUENT 5 June 6, 2007 03:00
