How to do linear spring coupling in STAR CCM+?
Old   November 29, 2017, 11:41
Default How to do linear spring coupling in STAR CCM+?
sarva
oe15d033 is on a distinguished road
Hi All, I am trying to do simulate the Vortex Induced motion of Cylinder(3D case ) in the current case. So I tried to use a spring-mass system. But it is not working fine, i.e I didn't get a proper curve of translation pattern in cross-line direction and the spring disconnect from the cylinder after some iterations. So anyone suggests me about spring - structure coupling.
Thanks in advance.
oe15d033 is offline   Reply With Quote
Old   December 24, 2017, 17:16
Ping
ping is on a distinguished road
the key to getting springs to work properly is in the coordinate system settings for each end of the spring and it sounds like the inner ends in your example are not created under the moving body coordinate system so they do not follow the body's motion
ping is offline   Reply With Quote
linear spring, spring-mass system, vortex induced motion
Star ccm and olga coupling Mohtta STAR-CCM+ 0 December 7, 2016 02:40
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
