March 27, 2017, 09:06 |
Counting the number of particles in a region
Georgios Sartzetakis
Rep Power: 9 |
Hello CFD community,
It is my first post hear however i have been following the forum for quite a while looking for answers. My question has been applied before by several users but it does not seem that i get a clear answer. So, i have domain which contains two regions which are separated by an internal interface. From one region i am injecting particles using the Lagrangian multiphase. I need to count the number of particles that exist at each region at every time. I have already tried the boundary sampling but with no luck. Maybe i am doing it wrong so if someone could give clear directions of how to proceed would be great. Element count does not work since it count the number of cell in the region. As i have understood the most viable procedure is through the boundary sampling. Please help Best, Georgios |
March 27, 2017, 09:09 |
the same problem
Antonis
Rep Power: 9 |
I have almost the same problem with Giorgio DTU and I have no idea how to solve it.
March 27, 2017, 09:42 |
Rep Power: 24 |
This question is covered in the user guide. Please read the section on langragian post-processing. You can use the element count report to easily count the number of particles in any region.
March 27, 2017, 12:14 |
Rep Power: 9 |
Hello me3840,
Thank you for the quick reply. I guess the suggested solution is in the part Post processing Lagrangian data and the subsection you are referring about is the ''Local instataneous data'' at page 4374 of the user guide(version 11.02). I followed the exact procedure but did get any results. I am attaching photos with the procedure i followed and please correct me if you find something incorrect. The problem is that despite the fact that there are particles already specified in the region with index 2 , the element count does not find any particles there. I am really sorry for the long post and i hope your eye sees something that mine cannot. Best Regards, Georgios |
March 30, 2017, 16:24 |
Rep Power: 10 |
It seems the region you are trying to separate has a region index of 2.0, right? In this case I would use a range of [1.5,2.5] instead of [2.0, 2.0].
March 30, 2017, 17:24 |
Rep Power: 9 |
Hello Schwob77,
You are right. I am trying to count the particles in region 2. I just tried what you suggested but unfortunately didn't work. Thank you for your interest nevertheless. Best, Georgios |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
dsmcFoam - micro-hole limiting the number of dsmc particles | Araist | OpenFOAM Running, Solving & CFD | 0 | June 25, 2015 06:50 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
AMI interDyMFoam for mixer | danny123 | OpenFOAM Running, Solving & CFD | 4 | June 19, 2013 04:49 |
