Result file Help
Old   August 11, 2011, 02:29
Post Result file Help
kid
cfdkid
kid is on a distinguished road
Hello All,
How do i extract value from result files in time stamp from OpenFOAM??
a cylinder flow was solved now i want to plot pressure around cylinder at all angles
at a particular distance. But i do not know how to extract the pressure value from "p" file.
Cheers
CFDkid
kid is offline   Reply With Quote
Old   August 11, 2011, 08:41
Question OpenFOAM
kid
cfdkid
Can you people help me please ?
Old   August 11, 2011, 10:42
David Gaden
marupio is on a distinguished road
Hey kid,
You can used Paraview to visualize your data. I believe it has data extraction functionality, but I haven't used it. You can use OpenFOAM's "sample" application. I think you need to add a sampleDict file to your constant directory to use it. sample extracts data from a set of points, or a plane. You can also export OpenFOAM data to other post processors, such as Techplot.
I don't know much more... I'm more into solver development!
-Dave
marupio is offline   Reply With Quote
Old   August 11, 2011, 11:53
Tobias
flotob is on a distinguished road
hi kid,
you could use the writeCellCentres utility to get the xyz coordinates of the points, your p data is calculated
tobi
flotob is offline   Reply With Quote
Old   August 12, 2011, 03:20
Thumbs up
kid
cfdkid
@Dave
Thank you will try sampleDict option
Originally Posted by marupio View Post
Hey kid,
-Dave
Old   August 12, 2011, 03:22
Thumbs up
kid
cfdkid
@tobi,
Well tried it from case directory, but it generated data for all the time step and cx,ccy,ccz
what are these files ?
Can i use it for getting data for particular cell ?
Cheers
CFDkid
Originally Posted by flotob View Post
hi kid,
tobi
Old   August 30, 2011, 06:00
Thumbs up Para Inspector to spot values in given cell
kid
cfdkid
Hello everyone,
Q: How to get values at particular location from result files of OpenFOAM?
A: ParaView comes with a python tool called Para Inspector. First open the OpenFOAM solved case in ParaView. Now to under View option and check the "para Inspector"
It asks for X,Y,Z co ordinates of the spot one wants to get or fetch values. One can also select between range of variables for which the values are computed. Next Zoom in at the spot and you will find the computed value.
Following links are useful in the above regard:
http://www.vtk.org/Wiki/Data_Selection
Cheers,
CFDkid
Old   August 30, 2011, 06:06
Joel Lehikoinen
joel.lehikoinen is on a distinguished road
Originally Posted by kid View Post
Hello everyone,
Cheers,
CFDkid
To obtain data values at single points, you can also use the probeLocations utility. For an example of probesDict, see $FOAM_TUTORIALS/postProcessing/sampling/probeLocations/probesDict.
joel.lehikoinen is offline   Reply With Quote
Old   August 30, 2011, 08:11
Post Thanks
kid
cfdkid
Will try it soon.
Cheers,
CFDkid
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 03:26
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
