error with icoDyMFOAM; how to set face extrusion zones |
May 9, 2011, 04:35 |
koji kiyono
Rep Power: 16 |
Hello.
I am trying to set up a case in OpenFOAM-1.5-dev and run it using icoDyMFoam, but the solver doesn’t work well. When I run the solver it gives me the following error: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5-dev | | \\ / A nd | Revision: exported | | \\/ M anipulation | Web: http://www.OpenFOAM.org | \*---------------------------------------------------------------------------*/ Exec : icoDyMFoam Date : May 09 2011 Time : 00:11:07 Host : ubuntu PID : 7177 Case : /home/kiyono/OpenFOAM-1.5-dev/applications/solvers/incompressible/icoDyMFoam/Topo2D2 nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh movingConeTopoFvMesh --> FOAM Warning : From function dlLibraryTable:pen(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file /build/buildd/openfoam-dev-1.5-1726/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/dlLibraryTableTemplates.C at line 68 library "libtopoChangerFvMesh.so" did not introduce any new entries Updating vertex markup. curLeft: 0.004 curRight: 0.008 Time = 0 Adding zones and modifiers to the mesh zone: 0() zone: 0() Adding mesh zones. Face extrusion zone contains no faces. Please check your mesh definition. From function void Foam::layerAdditionRemoval::checkDefinition() in file polyMeshModifiers/layerAdditionRemoval/layerAdditionRemoval.C at line 88. FOAM aborting Although I set up a case similar to movingConeTopo in the tutorials, face extrusion zone contains no faces in my case. What is the problem? Any help you can provide will be kindly appreciated. |
June 17, 2011, 16:07 |
Sarah
Rep Power: 15 |
Still working on a similar problem, but here's another thread that may point folks like me in the right direction.
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 19:25 |
Face Set Constructor for star v4.02 | gonnafon | Siemens | 1 | June 6, 2012 10:16 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Viewing Face Zones | Naghman Khan | FLUENT | 1 | September 24, 2007 17:23 |
WARNING: non-positive face area exist. | Alan | Main CFD Forum | 4 | August 17, 2006 08:33 |
