April 13, 2011, 06:57 |
Cyclic GGi
Kurne
Rep Power: 16 |
Dear All
My case is of Turbo machinery and i am using OpenFOAM 1.5-Dev.I have successfully transfer the mesh from the Ansys ICEM to Open Foam and now i want to use cyclicggi to two patches.Can any one tell me what necessary changes to make and where.I am in great need of it. Please Help. Thanks In Advance.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne |
April 15, 2011, 07:06 |
Kurne
Rep Power: 16 |
Dear All
Please tell me. I am in need of it.
April 15, 2011, 08:15 |
Check here for a test case with regards to GGI (Thanks to Olivier Petit, Maryse Page, Håkan Nilsson and Martin Beaudoin)
for cyclicGGI the procedure for faceSet and faceZone creation is same as GGI The definition in constant/boundary file is something like: cylic_left { type cyclicGgi; nFaces 100; startFace 1211; shadowPatch cyclic_right; zone cyclic_left_zone; bridgeOverlap off; rotationAxis (0 1 0); rotationAngle 90; separationOffset (0 0 0); } cylic_right { type cyclicGgi; nFaces 100; startFace 1311; shadowPatch cyclic_left; zone cyclic_right_zone; bridgeOverlap off; rotationAxis (0 1 0); rotationAngle 90; separationOffset (0 0 0); } Where the entries are self explanatory.......... Also, The boundary type in the 0/ directory for all fields is cyclicGGI. Hope that helps !! Cheers ! Amol
Amol Gode |
April 18, 2011, 07:19 |
Kurne
Rep Power: 16 |
Dear Amol Gode
Thanks a lot for guiding me.I have done all the necessary changes in constant/polymesh/boundary file.My case is of turbo machinery and i am using simpleSRFFoam solver. I have applied the correct boundary conditions also but still i am getting the error which is as follows. CCreate time Create mesh for time = 0 Reading field p Reading field Urel Reading/calculating face flux field phi Face zone name PERI1_zone not found. Please check your GGI interface definition. From function label ggiPolyPatch::zoneIndex() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 404. FOAM aborting Aborted The error is showing that PERI1 zone not found but the PERI1 patch is there. Will anybody help me. Thanks In Advance.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne Last edited by kurne; April 18, 2011 at 07:35. |
April 18, 2011, 10:12 |
#5 | |
Can be checked in constant/polyMesh/faceZones Also the face zone name 'PERI1_zone' seems to present in the definition of GGI / cyclicGGI interfaces, though actually not available as a face zone. Amol
Amol Gode |
April 19, 2011, 01:52 |
Kurne
Rep Power: 16 |
Dear Amol
I have check the constant/polyMesh/faceZones directory and in this directory only numbers are present means there is no names of zones as i have transfer the mesh from the ICEM to OpenFOAM.In boundary file i have edited the patches to be made cyclicGgi and which is given below PERI1 { type cyclicGgi; nFaces 2517; startFace 758483; shadowPatch periodic_sh; zone PERI1; bridgeOverlap off; rotationAxis (0 0 1); rotationAngle -72; separationOffset (0 0 0); } periodic_sh { type cyclicGgi; nFaces 2517; startFace 761000; shadowPatch PERI1; zone periodic_sh; bridgeOverlap off; rotationAxis (0 0 1); rotationAngle 72; separationOffset (0 0 0); } I have correctly edited the cyclicGgi interfaces and you can check once again.What is the problem i am unable to recognize.Please help to sort out this problem.Can anybody help me. Thanks in Advance.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne Last edited by kurne; April 19, 2011 at 08:33. |
April 19, 2011, 07:11 |
#7 | |
The faceZones file should look something like: FoamFile { version 2.0; format ascii; class regIOobject; location "constant/polyMesh"; object faceZones; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 2 ( periodic_sh_ZONE { type faceZone; faceLabels List<label> 36 ( ... //faces in periodic_sh_ZONE .... ) ; flipMap List<bool> 36{0}; } PERI1_ZONE { type faceZone; faceLabels List<label> 36 ( .... //faces in PERI1_ZONE ..... ) ; flipMap List<bool> 36{0}; } ) If not then please check the steps taken for creation of faceSets and faceZones. Check the tutorial on OpenFoamWiki referred to above. Amol
Amol Gode |
April 19, 2011, 08:32 |
Kurne
Rep Power: 16 |
Dear Amol
Thank you very much brother.I created the faceZone from the tutorial file.But i am facing the same problem as you face and mention here http://www.cfd-online.com/Forums/ope...implefoam.html When i run the solver i get the error Create time Create mesh for time = 0 Reading field p Reading field Urel Reading/calculating face flux field phi Problem with patch-to zone addressing: some patch faces not found in interpolation zone From function void ggiPolyPatch::calcZoneAddressing() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 77. FOAM aborting Aborted Hope this would be the final error and as you know the solution of it also please help brother. Thank You very Much Once Again.
April 20, 2011, 04:24 |
#10 |
Kurne
Rep Power: 16 |
Dear Amol
I have check all the things mention in that thread but still getting the error.Hope you help me now. I get the faceZones file as given below ) ; flipMap List<bool> 731419{0}; } periodic_sh_zone { type faceZone; faceLabels 0(); flipMap 0(); } PERI1_zone { type faceZone; faceLabels 0(); flipMap 0(); } ) And my boundary file is as follows PERI1 { type cyclicGgi; nFaces 2517; startFace 758483; shadowPatch periodic_sh; zone PERI1_zone; bridgeOverlap off; rotationAxis (0 0 1); rotationAngle -72; separationOffset (0 0 0); } periodic_sh { type cyclicGgi; nFaces 2517; startFace 761000; shadowPatch PERI1; zone periodic_sh_zone; bridgeOverlap off; rotationAxis (0 0 1); rotationAngle 72; separationOffset (0 0 0); } Thanks In Advance.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne Last edited by kurne; April 20, 2011 at 08:17. |
April 20, 2011, 06:12 |
#11 |
Wei Zhao
Rep Power: 16 |
April 20, 2011, 06:35 |
#12 |
Kurne
Rep Power: 16 |
Dear Wei Zhao
Thanks a lot for it and it is new case file but the problem solution is not in it.Anyway thanks a lot for new case files.
April 21, 2011, 06:19 |
#13 |
Kurne
Rep Power: 16 |
Dear Amol
Thank you very much brother my case got work. Thanks A Lot Once Again.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne Last edited by kurne; April 21, 2011 at 07:15. |
October 23, 2013, 03:07 |
turboPassageRotating2d
#14 |
Minh-VietNam
Rep Power: 13 |
Hi. Everybody.
I'm a new openFoam user. so i can not launch this case. I don't know how to fix the error. Can you help please.? This is case (case of an master thesis which downloaded from web http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/) thanks a lot! ====== This is error: --> FOAM FATAL IO ERROR: Cannot find 'value' entry on patch rotor_cyclic_upper of field p in file "/home/minh/Desktop/turboPassageRotating2D/0/p" which is required to set the values of the generic patch field. (Actual type cyclicGgi) Please add the 'value' entry to the write function of the user-defined boundary-condition file: /home/minh/Desktop/turboPassageRotating2D/0/p.boundaryField.rotor_cyclic_upper from line 43 to line 43. From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&) in file genericFvPatchField/genericFvPatchField.C at line 71. FOAM exiting +++ Please show to me, thankS! Last edited by mingbn; November 1, 2013 at 02:40. |
February 25, 2018, 18:09 |
#15 |
Metikurke
Rep Power: 9 |
November 10, 2019, 01:04 |
#16 | |||
Hojatollah Gholami
Rep Power: 7 |
Dear foamer
I try to model a rectangular domain with discontinue top and bottom patch. I want to use cyclicGgi for top and bottom. the mesh generated by ANSYS Meshing and cyclicGgi defined to top and bottom. The problem is when running simulation the FatalErrorIn Reconstructed cell centres already calculated occurs. this error is in ggiPolyPatch.C file and due to Quote:
batch.setSet is Quote:
November 11, 2019, 15:25 |
#17 |
Hojatollah Gholami
Rep Power: 7 |
Any foamers deal with this problem?
November 12, 2019, 10:52 |
#18 |
Sandeep Menon
Rep Power: 25 |
Looks like a bug where demandDrivenData (in this case, reconFaceCellCentresPtr_) isn't being cleared correctly when a topology change occurred.
November 14, 2019, 03:43 |
#19 |
Hojatollah Gholami
Rep Power: 7 |
1- I thought the error may introduce from mesh, because the imported mesh with fluent3DMeshToFoam give non-aligned cells. I replaced 3D mesh with 2D mesh and use fluentMeshToFoam (checkMesh is OK) but still the problem exist.
2- I separate the top and bottom to check, may problem is due to meshing, but for structured and unstructured mesh, still the problem exist. 3- I use non-conformal top/bottom mesh, but problem still exist. 4- I change position of rectangular from symmetry of x axis to positive region (Y), but still problem exist. The test was done with other geometry TurekHronFsi tutorial with blockMesh and generated mesh with ANSYS Meshing and then changing top and bottom wall to cyclicGgi. the simulation works correctly with cyclicGgi. But for this geometry, it can't. Why? I check each part (1,2,3) aside but the error exist. Despite, this geometry with cyclic condition work properly in serial running. |
November 15, 2019, 02:11 |
#20 |
Hojatollah Gholami
Rep Power: 7 |
Another try: The simulation for my geometry work with fluidFoam correctly. But with fsiFoam give error.
In fluidFoam the cellMotion doesn't consider. But in fsiFoam it considers. As the pointMotionU can't define cyclicGgi, I use fixedValue with Value (0 0 0) or calculated, that give error "Attempting to create reconFaceCellCentres on a shadow" after calculating pointMotionUx, pointMotionUy. That is before calculating U and p. |
Ggi | FabOr | OpenFOAM | 17 | May 9, 2013 11:19 |
Cyclic vs ggi vs directMapped Patches | jens_klostermann | OpenFOAM Running, Solving & CFD | 33 | May 3, 2013 03:45 |
Difference between ggi and overlapGgi? GGI Tips and Tricks? | philippose | OpenFOAM Running, Solving & CFD | 7 | January 16, 2013 10:40 |
GGI in OpenFOAM-1.5-dev | philippose | OpenFOAM Running, Solving & CFD | 14 | November 13, 2011 15:55 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 18:08 |
