Mesh generator with OpenFoam / Urban Design
Like Tree1Likes
Old   November 4, 2010, 07:56
Takuya OSHIMA
7islands is on a distinguished road
We are in the process of validating OpenFOAM against other CFD codes, wind tunnel tests and field measurements using benchmarking test cases defined by a Japanese academic society (or its journal article if you prefer paper form) for urban wind environment predictions. If you follow the link you'll find 8 cases, cases A - H, simulating urban environments with varying reality, ranging from simple blocks to realistic urban terrains. Among those we have finished cases A - F, and in the process of publishing the case data so that any OpenFOAM users can reproduce our results. The test cases Elvis mentionedare cases E and D respectively which my colleague (the author of the aforementioned presentation slides) has just published. We should be able to publish other cases as well shortly, among them cases E and F are realistic sHM cases enough to get an idea about how sHM works for urban terrains.
Takuya
7islands is offline   Reply With Quote
Old   November 8, 2010, 08:47
Masashi IMANO
imano is on a distinguished road
Hi Guillaume,
I'm sorry for late reply.
I'd like to answer your 1st and 4th questions (thanks a lot Takuya for
answering 2nd and 3rd)
Originally Posted by Voyage_gui View Post
- from a clean CAD file (after post-processing of aerial laser scanned geographical data), how long did it take him to mesh the whole district ?
It takes about one hour in 16 cpu parallel as listed below:
blockMesh (in single): 1 min.
decomposePar (in single): 1 min.
snappyHexMesh (in 16 cpu parallel): 40 mins.
reconstructParMesh (in single): 17 mins.
- Does he have any papers regarding urban design ?
My English papers for CFD prediction of urban environment are very few so
far, but have a look at e.g.:
http://dl.dropbox.com/u/3609076/Vent...per_ver.2_.pdf
http://dl.dropbox.com/u/3609076/Vent...2009100201.pdf
7islands : Thks for the LES presentation. Too bad i don't know japanese (by any chance same document in English?). Was he satisfied by the result of the DES simulation (any exp. measure to compare with) ?
Guillaume
There is no English document for this presentation, sorry.
Moreover I couldn't validate LES or DES simulation since I didn't have
any measurement data to compare with in this case.
As Elvis and Takuya mentioned in previous posts, I uploaded
OpenFOAM tutorial cases which predict urban wind environment and
validate with wind tunnel measurement data.
Though these cases use RAS model as turbulent model, but it's easy to
change it to VLES or DES if you share the mesh for the RAS calculation.
So please try validating these benchmark tests with VLES or DES model
and report the results if you have spare time
Masashi
imano is offline   Reply With Quote
Old   October 9, 2013, 02:51
izna O'connor
izna is on a distinguished road
hello..
I am hijacking this post.
I am simulating a flow over an urban area, but i am working in 2D, i am obtaining convegence with simpleFOam but when view in paraview its as if no wind has enter my domain..
Can you please advice me on the boundary conditions used? I tried SLip and inletoutlet all in vain...
I am using RAS model, with GAMG solver .
My east side of domain is inlet and the three remaining sides ie north south and west are outflow where my wind is supposed to go ...
But i need help in the boundarycondition..
kind regards
izna
izna is offline   Reply With Quote
Old   October 9, 2013, 22:36
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Izna,
Probably best to create a new post for your question...
Can you post your U and p directory?
Julien
julien.decharentenay is offline   Reply With Quote
Old   October 10, 2013, 01:43
izna O'connor
hi.. thanks a lot for the reply.. below is my u and p dire.. also sides means the north and south sides... its in 2D
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
wall
type fixedValue;
value uniform (0 0 0);
outflow
type zeroGradient;
inlet
type fixedValue;
value uniform (-4 0 0);
sides
type fixedValue;
frontAndBackPlanes
type empty;
nFaces 67650;
startFace 68115;
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
outflow
type fixedValue;
value uniform 0;
inlet
type zeroGradient;
sides
type zeroGradient;
frontAndBackPlanes
type empty;
nFaces 67650;
startFace 68115;
Old   October 10, 2013, 02:40
Thanks. Nothing obviously wrong with the two files. Can you send some more information (mesh, solver output, screenshot)?
Old   October 10, 2013, 03:40
izna O'connor
hi.. meshwas done in Gambit.. converted to FOam..
solver PCG i am putingh FV solution here
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.1;
pFinal
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
k
solver PBiCG;
tolerance 1e-05;
relTol 0;
epsilon
solver PBiCG;
tolerance 1e-05;
relTol 0;
R
solver PBiCG;
tolerance 1e-05;
relTol 0;
nuTilda
solver PBiCG;
tolerance 1e-05;
relTol 0;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-2;
U 1e-3;
"(k|epsilon|omega)" 1e-3;
residualControl
p 1e-3;
U 1e-4;
each time after certain number of iterations i obtain my program is crashing..hence one picture which i was able to view before crashing.. you can clearly see that in thsi pic, thhe simulations was partly stopped...
Old   October 10, 2013, 03:44
izna O'connor
we can see it has not simulated to convergence.. but how to make it converge without crashing???
Old   October 10, 2013, 06:05
izna O'connor
when i do the BC as symmetryPlane i obtain the errors...
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
--> FOAM Warning :
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/Field.C at line 262
Reading "/home/izna/Desktop/y/0/k" from line 18 to line 54
expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
No finite volume options present
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.07582883344e-05, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.95605000958e-06, No Iterations 301
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0999726835198, No Iterations 584
time step continuity errors : sum local = 29.8522772566, global = -0.0024880751966, cumulative = -0.0024880751966
DILUPBiCG: Solving for epsilon, Initial residual = 0.999913801056, Final residual = 1.00016301843, No Iterations 1001
bounding epsilon, min: -219.225697355 max: 207.638755413 average: 0.998265362431
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.13408135894e+12, No Iterations 1001
bounding k, min: -4.17424118765e+16 max: 8.29450514701e+16 average: -1.52614847385e+12
ExecutionTime = 424.6 s ClockTime = 425 s
Time = 2
DILUPBiCG: Solving for Ux, Initial residual = 0.801813491704, Final residual = 0.801813491704, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.659490592026, Final residual = 0.659490592026, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.999998931991, Final residual = 2762872.03121, No Iterations 1001
time step continuity errors : sum local = 7.05385314245e+12, global = 12013.6485228, cumulative = 12013.6460347
DILUPBiCG: Solving for epsilon, Initial residual = 0.246233904231, Final residual = 369.290447986, No Iterations 1001
bounding epsilon, min: -1.8042009224e+36 max: 6.34190622628e+35 average: 2.79678186829e+31
DILUPBiCG: Solving for k, Initial residual = 1.62772660345e-13, Final residual = 1.62772660345e-13, No Iterations 0
ExecutionTime = 814.39 s ClockTime = 816 s
Time = 3
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam:ILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 Foam:ILUPreconditioner:ILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#5 Foam::lduMatrix:reconditioner::addasymMatrixCons tructorToTable<Foam:ILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/simpleFoam"
#11
#12 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#13
Floating point exception (core dumped)
Old   October 10, 2013, 22:25
Izna,
What is your question/request for assistance?
Your post 9.10:
Your post 10.10:
Old   October 11, 2013, 04:45
izna O'connor
i am sorry.. its just i am trying a lot of different solvers..
My question is i want to obtain a velocity start from the east side of my domain.. but i am obtaining the followig picture..
Old   October 12, 2013, 08:00
No drama. It is getting clearer. I can't see anything wrong from the dictionary, but have to admit that I have not done 2D simulations... So there are a few of the "tricks" that I do not know.
Could you post a link to a complete case for download and try?
Old   October 12, 2013, 08:39
izna O'connor
yesh am going to send a link..thnaks heaps Julien..
Old   October 13, 2013, 07:23
Hi Izna,
Thanks for sending the case through. It helps - even though I have not tried to run the model. Below are two suggestions:
1) North and South boundaries:
In your setup, these are defined as "outlet" boundary conditions. I understand that you are using this approach as you would like to allow for exit/re-entry of fluid. This set of condition is what creates in your case the high in-velocity observed in the picture.
My recommendation is to change these conditions to symmetry (for the north and south faces only). If you are concerned about flow exit/re-entry, you can evaluate the impact of the domain size (in width) on the variable of interest by doubling the domain size in the width direction.
2) West boundary condition:
The setup is a zero velocity gradient and zero pressure. I personally prefer to change it to an inlet/outlet setup where the backflow velocity is specified as zero. It operates as the outlet you defined as long as the flow is going out, but prevent backflow. I found this approach more stable. Although this may have some impact, the above suggestion should be sufficient.
Let me know if you try any of the above and if they work (as a separate thread).
Old   October 13, 2013, 14:11
izna O'connor
hello Julien
http://www.cfd-online.com/Forums/ope...tml#post456673
this is the new thread please do check.
izna
Old   September 21, 2016, 00:19
JIN WEIGUO
Mark JIN is on a distinguished road
Hey Guys, your discussions are really helpful, thanks!
Mark JIN is offline   Reply With Quote
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Harpoon and OpenFoam - Mesh and simpleFoam scott OpenFOAM 4 September 4, 2009 08:48
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
