svn
Old   April 12, 2010, 07:01
Default svn
NAVEEN.K.M
naveen is on a distinguished road
hi everybody,
I am from INDIA working in OpenFOAM past 1.5 years at National Aerospace Laboratories on a different projects like flow over aerofoils, wings, full aircraft, cylinders using OpenFOAM 1.4.1, 1.5, 1.6.x for CFD Analysis.Now i want to work on Turbomachinery applications(like centrifugal pump, turbines etc) using OpenFOAM.For this i want to use the GGI Interface application, for this i want to install OpenFOAM 1.5-dev version of OpenFOAM. Can you please suggest me how to install this version and also how to download the svn repository from the sourceforge.net and also i want to know how to register in svn to use and download from this website through command prompt
(svn co https://openfoam-extend.svn.sourceforge.net/
svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev). If i enter the above mentioned website i am getting the following error at the terminal
svn: PROPFIND request failed on '/svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev'
svn: PROPFIND of '/svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev': Could not resolve hostname `openfoam-extend.svn.sourceforge.net': Temporary failure in name resolution(https://openfoam-extend.svn.sourceforge.net).
can you please suggest me where i am going wrong and also explain me how to install OpenFOAM 1.5-dev from initial point.
naveen is offline   Reply With Quote
Old   April 12, 2010, 07:31
Philippose Rajan
philippose will become famous soon enough
Hello Naveen,
To me it looks like a problem with the Firewall on your system or on the server which your system uses to access the internet.
If you are using a Proxy server to access the Internet, you need to setup SVN to work with the proxy server...
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   April 12, 2010, 07:50
Default svn
NAVEEN.K.M
hi Philippos sir,
yes, I am using Proxy server to access the Internet.can you give me some suggestions how to setup SVN to work with the proxy server and where i have to set these settings (i am using Mandriva 2008.1).
regards
Naveen
Old   April 12, 2010, 12:18
Philippose Rajan
Hello Naveen,
In your home directory, you should have a hidden folder called ".subversion"...
Within this folder there should be a file called "servers"
You need to open this file with a text editor, and change the following lines under the [global] section according to your proxy server settings:
# http-proxy-host = defaultproxy.whatever.com
# http-proxy-port = 7000
# http-proxy-username = defaultusername
# http-proxy-password = defaultpassword
(Don't forget to remove the "#" in front of the lines to uncomment them)
Hope this helps!
Philippose
Old   April 15, 2010, 05:36
Default svn
NAVEEN.K.M
hi Philippos sir,
Very Very thank you for your help . Now i am able to get the OpenFOAM 1.5-dev version from the svn repository using the code
( svn co http://openfoam-extend.svn.sourcefor...-extend/trunk/
Core/OpenFOAM-1.5-dev/).
once again thank you very much.
---Regards----
Naveen
Old   April 19, 2010, 07:57
Thumbs up Open Foam
Madhukar@NAL
madhukar_nal is on a distinguished road
Hi...
i am also facing same problem..can any body tell how to install?
madhukar_nal is offline   Reply With Quote
Old   June 8, 2010, 01:38
Madhukar@NAL
Originally Posted by naveen View Post
hi everybody,
Hi Naveen & Every one
...i have one doubt..How to install Open Foam...Plz send me a step by step procedure.
Old   June 8, 2010, 01:39
Default nice to meet u...
Madhukar@NAL
hi everybody,
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
OpenFOAM-1.5-dev svn revision 1438: ParaFoam does not compile 4xF OpenFOAM Bugs 1 October 16, 2009 06:41
SVN 1226 - Possible bug with cell centres and volumes philippose OpenFOAM Bugs 2 June 5, 2009 14:19
141dev svn repository egp OpenFOAM Installation 1 August 25, 2008 17:10
Accessing the SVN Repository Howto philippose OpenFOAM Installation 3 August 31, 2007 16:39
