Multiphase flows (oil with small particles)
Old   December 29, 2009, 10:49
Default Multiphase flows (oil with small particles)
Sami Lakka
sami_lakka is on a distinguished road
I stumbled in to an interesting case where I would need to get most of the small particles in oil to collide with pipe wall (or other obstruction). In order to look into this I need to simulate how small oil particles (10 - 100 microns) flow in oil. What would be the preferred solver for this case?
sami_lakka is offline   Reply With Quote
Old   January 10, 2010, 18:35
Alberto Passalacqua
You should give some indication of how many particles (concentration, volume fraction) you want to consider if you want a reliable answer.
If the flow is relatively dilute (particle volume fraction < 10%), you can use a lagrangian solver, while for higher volume fractions you need other approaches (Euler-Euler, for example).
Best,
Alberto Passalacqua
multiphase modelling
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 06:29
multiphase oil air separator tips matt giuli CFX 1 October 6, 2008 23:50
Free surface flows and multiphase flows Vidar Main CFD Forum 0 September 18, 2008 06:05
Continuity equation for Multiphase flows? discoganya Main CFD Forum 0 June 29, 2006 14:39
Multiphase Flows Elliot Schwartz Main CFD Forum 6 May 28, 1999 03:11
