SolidDisplacementFoam in Parallel
Old   July 15, 2009, 09:24
Default [Solved]: SolidDisplacementFoam in Parallel
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I am not able to run my model with SolidDisplacementFoam solver in parallel mode.
In serial I don't have any problem.
OF returns me that the executable SolidDisplacementFoam cannot be find.
I don't have problem running simpleFoam solver with parallel (up to 16cpu)
My question: Parallel option can be run with all sovers, or is there restrictions?
Edit: it was just a mistake in the command
Problem solved...
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM Bugs 17 April 29, 2013 00:44
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
