July 9, 2009, 14:55 |
coordinate depending source term
Jagmohan Meena
Rep Power: 17 |
Dear Sir/Madam,
I am doing a heat transfer problem with source term. Source term itself depends on the x,y,z, coordinates. I have tried following : Teqn: { fvScalarMatrix TEqn ( (rho)*(Cp)*fvm::ddt(T) + fvm::div(phi, T) - (rho)*(Cp)*fvm::laplacian(DT, T) == Q ); TEqn.relax(); eqnResidual = TEqn.solve().initialResidual(); maxResidual = max(eqnResidual, maxResidual); } Q is source term which is defined as: Info<< "Reading sourceProperties\n" << endl; IOdictionary sourceProperties ( IOobject ( "sourceProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); dimensionedScalar Acos ( sourceProperties.lookup("Acos") ); dimensionedScalar Rcos ( sourceProperties.lookup("Rcos") ); dimensionedScalar Zcos ( sourceProperties.lookup("Zcos") ); dimensionedScalar Q("Q", Acos*cos(0.5*3.14*(sqrt((x[0]*x[0])+(x[1]*x[1])))/Rcos)*cos(0.5*3.14*x[2]/Zcos)); if (Q < 0.) { Q = 0.0; } Error: readSourceProperties.H: In function ‘int main(int, char**)’: readSourceProperties.H:30: erreur: ‘x’ was not declared in this scope readSourceProperties.H:32: erreur: no match for ‘operator<’ in ‘Q < 0.0’ make: *** [Make/linux64GccDPOpt/sourceBuoyantSimpleFoam.o] Erreur 1 I thought to use x[0] for x, x[1] for y and x[2] for z ! but OpenFOAM reports error in this. Hence my question is: How to input coordinates for Q so that it OpenFOAM will understand it ? thankyou in advance !! regards, JM |
July 12, 2009, 14:44 |
Henrik Rusche
Rep Power: 18 |
Dear jmmeena,
1) Use mesh.C().x() for the x-coordinate 2) Your coordinate dependant source should be a volScalarField 3) Use max-function to bound Q @ zero Henrik |
July 15, 2009, 05:16 |
isabel
Rep Power: 17 |
Thank you very much, Henrik.
I have wrotten these lines in my code: volScalarField x = mesh.C().x(); volScalarField y = mesh.C().y(); and I have this error in these lines (line 89 and line 90): isabel@isabel-desktop:~/OpenFOAM/isabel-1.5/applications/solvers/multiphase/interFoamModificado$ wmake SOURCE=interFoamModificado.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/transportModels -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/transportModels/incompressible/lnInclude -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/transportModels/interfaceProperties/lnInclude -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/interFoamModificado.o In file included from interFoamModificado.C:84: pEqn.H: In function ‘int main(int, char**)’: pEqn.H:89: error: ‘const struct Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>’ has no member named ‘x’ pEqn.H:90: error: ‘const struct Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>’ has no member named ‘y’ /home/isabel/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nCorr’ make: *** [Make/linuxGccDPOpt/interFoamModificado.o] Error 1 isabel@isabel-desktop:~/OpenFOAM/isabel-1.5/applications/solvers/multiphase/interFoamModificado$ |
July 15, 2009, 05:37 |
Henrik Rusche
Rep Power: 18 |
Dear Isabel, dear jmmeena,
stupid me ... vector v; Info << v.x(); // OK volVectorField vf; Info << vf.component(vector::X); // OK Henrik |
July 15, 2009, 05:55 |
isabel
Rep Power: 17 |
Thank you very much, Henrik, but with these lines:
vector v; Info << v.x(); volVectorField vf; Info << vf.component(vector::X); I have this error (line 90 is “volVectorField vf;”) : isabel@isabel-desktop:~/OpenFOAM/isabel-1.5/applications/solvers/multiphase/interFoamModificado$ wmake Making dependency list for source file interFoamModificado.C SOURCE=interFoamModificado.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/transportModels -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/transportModels/incompressible/lnInclude -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/transportModels/interfaceProperties/lnInclude -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/isabel/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/interFoamModificado.o In file included from interFoamModificado.C:84: pEqn.H: In function ‘int main(int, char**)’: pEqn.H:90: error: no matching function for call to ‘Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField()’ /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:611: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::wordList&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:576: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::word&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:545: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:512: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:480: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:448: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:416: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:378: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, Foam::Istream&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:337: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:313: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensionSet&, const Foam::Field<Type>&, const Foam::PtrList<PatchField<Type> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:283: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::wordList&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:254: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:227: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensionSet&, const Foam::wordList&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.C:197: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensionSet&, const Foam::word&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/isabel/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nCorr’ make: *** [Make/linuxGccDPOpt/interFoamModificado.o] Error 1 isabel@isabel-desktop:~/OpenFOAM/isabel-1.5/applications/solvers/multiphase/interFoamModificado$ |
July 15, 2009, 06:06 |
#6 | ||
Henrik Rusche
Rep Power: 18 |
Dear Isabel,
Okay, you want to try: Quote:
July 15, 2009, 06:18 |
isabel
Rep Power: 17 |
Now it works. |
momentum source term | zwdi | FLUENT | 14 | June 27, 2017 16:40 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 14, 2000 00:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
