Refilling a Tank
Old   July 7, 2009, 11:21
Red face Refilling a Tank
Stefano
Whyman is on a distinguished road
Hi everybody!
I would like to propose you a problem that i'm trying to solve, but for now unsuccessfully.
I have a tank and i want to simulate the first refilling phase of it. The tank is pressurized at 3 bar of any gas, like air or helium: at the bottom of the tank there is the inlet surface where i want to introduce a liquid, with a decided flow rate and pressure (the pressure is 1.5 higher than the gas pressure). At the top instead there is another outlet surface where the gas is sucked in order to hold the tank pressure on.
At first sight it would be recommended a compressible multiphase solver, but for now it hasn't been developed yet.
I have tried to run the incompressible multiphase solver but it crashes almost immediately.
Do you know if this simulation is possible in OpenFoam?
Have you got any suggestions to give?
Thank you all
Bye
Whyman is offline   Reply With Quote
Old   July 8, 2009, 01:28
Giro
girogirozakk is on a distinguished road
Hi , stefano.
you can find interFoam's sample "fill water" in my URL.
that case may help you ?
http://giropenfoam.web.fc2.com/sample/interFoam/index.html
Bye
Giro
girogirozakk is offline   Reply With Quote
Old   July 8, 2009, 05:58
Smile It works
Stefano
Hi Giro,
thank you very much for your help. It's exactly what i needed. I'm trying to run the simulation right now and i hope to obtain the right results.
Maybe you can answer me to another question. Do you know if it's possible to simulate a spin velocity applied to the domain? I mean like to simulate a rotation velocity. For now i can only apply a costant acceleration, but i would like to see what happens when the domain is rotating with a constant velocity.
Thank you
Bye
Stefano
Old   July 8, 2009, 07:19
Eugene de Villiers
eugene is on a distinguished road
What is wrong with compressibleLESInterFoam?
eugene is offline   Reply With Quote
Old   July 8, 2009, 07:31
Smile It works
Stefano
Nothing wrong, but i would like to use the RANS formulation in order to make the simulation quicker.
Old   July 8, 2009, 08:44
Eugene de Villiers
In that case
- copy the LES version somewhere,
- rename it and replace all instances of "LESModel" with "RASModel" and all instances of "nuSgs2 with "nut".
- Change Make/file to rename the executable and FOAM_APPBIN to FOAM_USER_APPBIN
- Change Make/options and replace LES with RAS here as well. (Except LESdeltas which can be removed)
- Recompile.
- Done.
Old   July 9, 2009, 04:21
Giro
now , "inlet" boundary that is constructed with so many "face" , please replace to some inlet boundary(each face) that have controled velocity what you want.
if you write some program(script) for setup , it is not so tiresome.
other approach ,
if i try that type boundary with other approach, may be i make tube-type mesh for inlet.
that tube have spiral wall .
if that tube have enough length and spiral wall height , i can get spin velocity on the real inlet point(may be).
(may be tiresome to adjust...)
that is not so good?
Giro
refilling tank multiphase
how to maintain constant presure in a tank? JB FLUENT 5 July 31, 2008 06:12
Settling tank John Grimm FLUENT 1 March 20, 2005 09:20
tank leakage H FLUENT 0 October 4, 2004 21:28
Boiling and tank fill questions Mir CFX 1 April 28, 2002 18:45
Flow patterns in a stirred tank Glenn Price Main CFD Forum 13 March 20, 1999 11:16
