Collection of simple functionObjects
Like Tree3Likes
Old   June 7, 2014, 08:12
Assistant Moderator
Bernhard Gschaider
Originally Posted by Shahr View Post
I find this thread the best place to ask this question:
I disagree. This thread is about a package called simpleFunctionObjects which is not part of the OF release but of an addition called swak4Foam
I am looking for a list of variables I can do field operations on, e. g. fieldAverage, fieldMinMax, etc.
Basically every variable that is in memory. Check the output in directory 0.1 called foo then there is a variable foo you can exist. Of course fields that are not written are not found that way
I found some information about the new features added for version 2.2,
but I have no idea what possibilities are available.
There is a function object called listRegisteredObjects in swak4Foam/simpleFunctionObjects that gives you such a list. There may be similar FO in plain OF (but it wasn't at the time I wrote that FO). But to use that you'll have to install a full swak4Foam (sorry)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 14, 2014, 10:26
Shahr is on a distinguished road
Thanks Bernhard. My bad, I thought simpleFunctionObjects are part of main OF distribution, not swak4Foam. Nevertheless I checked listRegisteredObjects and found the list.
However, I would also like to know which fields are written into memory, and can be used/accessed by the main openfoam functionObjects, such as probes, fieldAverages, etc. Some of my runtime post-processing functions are to be OF built-in features.
Shahr is offline   Reply With Quote
Old   June 14, 2014, 17:40
Assistant Moderator
Bernhard Gschaider
What listRegisteredObjects lists is exactly that: all objects that can be accessed by others with simple knowledge of the name (or as you say: fields in memory).
Probes for example are not in that list because they are instantiated by the probes-functionObject. They can not be accessed from outside the functionObject
Old   June 14, 2014, 18:12
Well, thanks again. I found another possibility before your reply, and that is the writeRegisteredObject. I tried it and can confirm that it generates the same list as listRegisteredObjects from swak.
I guess the next step for me is to add the fields I need to the createFields so that I can use swak on them.
Huge thanks by the way for this amazing set of tools you wrote. It makes working with openfoam a bliss for a C++ illiterate user like me.
Old   June 15, 2014, 15:32
Assistant Moderator
Bernhard Gschaider
Which OF-version? The writeRegisteredObject I have the sources to is used to write objects that otherwise wouldn't be written. It relates to listRegisteredObjects like "cat" (the command) relates to "ls"
Thanks.
Old   June 25, 2014, 09:42
Sorry for the delay. I used it on OF23x. The output were similar tables only with different formatting. As I remember they contained same entries.
Old   July 2, 2014, 19:13
Assistant Moderator
Bernhard Gschaider
My guess: the list of objects in the error message if you specify a non-existing object
Old   July 31, 2014, 09:17
Ron
ron_OFuser is on a distinguished road
Hello Bernhard,
Is it possible to write drag coefficient on the cylinder using the swak4Foam-or-functionObjects for non-newtonian fluids?
ron_OFuser is offline   Reply With Quote
Old   July 31, 2014, 11:06
Assistant Moderator
Bernhard Gschaider
Originally Posted by ron_OFuser View Post
Hello Bernhard,
Of course. If you can calculate the drag force correctly
Variable deltaT and functionObjects henrik OpenFOAM Bugs 8 July 22, 2009 05:11
OF15 functionObjects do not read LESProperties for incompressible flows aunola OpenFOAM Bugs 1 September 28, 2008 18:18
Collection Codes OpenFoam larry OpenFOAM Running, Solving & CFD 0 July 3, 2006 18:11
Collection efficiency Jen FLUENT 0 November 16, 2005 11:16
Data output collection simon Main CFD Forum 0 September 29, 2003 10:03
