Dynamicmeshdict - Rotation tensor in orientation
Old   November 16, 2023, 03:01
Exclamation Dynamicmeshdict - Rotation tensor in orientation
Rohan
Rohanbotta is on a distinguished road
Hello, i have run the wingmotion2D tutorial of Openfoam V10, through which ive been trying to learn dynamicmeshdict. The tutorial consists something called orientation which i got to know is a rotation tensor.
centreOfMass (0.4974612746 -0.01671895744 0.125);
momentOfInertia (1.958864357 3.920839234 2.057121362);
orientation
0.9953705935 0.09611129781 0
-0.09611129781 0.9953705935 0
0 0 1
angularMomentum (0 0 -2);
g (0 -9.81 0);
rho rhoInf;
i tried changing the values in the orientation matrix but it always shows an error: the given orientation is not a rotation tensor, and some equation saying mag(orientation) - sqrt(3) = some value.
It would help me lot if i can learn how to change the orientation correctly and what is the sqrt(3), im assuming its because of rotation about 3axes (i might be wrong).
i changed the values based on a rotation tensor matrix equation i found somewhere which included the angle of rotation about each axis, yet the error continues. i would really appreciate the help to know how to use the orientation in dynamicmeshdict.
Thank you,
Regards
Rohan
Rohanbotta is offline   Reply With Quote
Old   November 17, 2023, 08:05
Rohan
So, i somehow resolved the error, but now it seems like even if i change the angle in orientation the mesh isnt rotating about that angle but only until the default tutorial setup, i have also tested the force results before and after changing orientation, but they seem to not change at all.
would really appreciate the help.
Thank you
#dynamicmeshdict, #openfoamcase, #pimplefoam
How to assign dynamicMeshDict for 1 full body rotation + 2 ailerons deflection quarkz OpenFOAM Running, Solving & CFD 2 October 31, 2020 05:10
Java Macro -- Passive Pith in Superposing Rotation Motion Weidong Dai STAR-CCM+ 2 August 4, 2018 06:39
dynamicMeshDict settings for multi rotation benoitf OpenFOAM 0 June 14, 2018 11:26
orientation in dynamicMeshDict fluidpage OpenFOAM Running, Solving & CFD 1 April 13, 2018 04:11
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
