OpenFOAMv7 WAVE Generation Problem
Old   January 18, 2022, 11:12
Default OpenFOAMv7 WAVE Generation Problem
Tony Zhang
zyfsoton is on a distinguished road
Hi all, I had an issue when using OFv7 to simulation a ship in wave condition.
As far as I know, OpenFOAM has included its own wave generation tool since OFv5.
To start with, I copied the DTCHullWave tutorial case into my own directory then I replaced the STL file and then did my own blockMesh, refineMesh and snappyHexMesh etc. Then I did renumberMesh, the error reported:
--> FOAM FATAL IO ERROR:
Essential entry 'value' missing
file: /home/OpenFOAM/OpenFOAM-7/run/KCSDRIFTINWAVE/0/U.boundaryField.inlet from line 31 to line 31.
Then I had to add value in alpha.water and U files in 0 folder (value $internalField; in both inlet BCs in both files)
Then setWaves and decomposePar ran smoothly without any error.
Finally, running interFoam, error reads: Unknown patchField type waveVelocity for patch type patch; (/0/U.boundaryField.inlet)
I think the same error will reported in 0/alpha.water.inlet as well for Unknown patchField type waveAlpha for patch type patch;
Please let me know if you have any hint to resolve this issue! Many thanks and Btw I am using OF version 7 and the patches of waveAlpha and waveVelocity should have been included in OFv7, and I can run DTCHullWave tutorial case without any error!
Btw, I am not sure whether it is worth installing a third party wave generation tool eg. wave2Foam in OpenFOAM v7?
Any help will be appreciated!
Tony
zyfsoton is offline   Reply With Quote
Dirichlet wave generation (DWG) pipi REEF3D 2 December 1, 2021 20:34
How can we determined wave decay cause artificial problem or physically reasonable? Tlinxo Main CFD Forum 1 June 9, 2021 13:15
[waves2Foam] irregular wave problem yangzhou OpenFOAM Community Contributions 0 July 19, 2017 09:42
[waves2Foam] regular wave generation attenuation yangzhou OpenFOAM Community Contributions 3 June 29, 2017 05:34
Free surface wave pattern generation sam FLUENT 1 January 2, 2004 17:12
