November 13, 2020, 04:49 |
set bubble diameter in openfoam
Muhammad Ahyar
Rep Power: 6 |
i am in a project which modelling the flotation tank. first i want to set the bubble diameter into nanometer size. is there any utility or method in openfoam to set the bubble diameter parameter? thanks in regard
November 17, 2020, 03:46 |
Rep Power: 8 |
i don't know which solver you are using, it would really help when you tell about that first. for example, for the multiphase euler solvers the diameter is in phaseProperties in the constant folder.
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
