November 2, 2020, 04:17 |
fvDOM in radiation
ethan oh
Rep Power: 15 |
hello foamers.
I validate fvDOM radiation model in OpenFOAM v8. Why is it different from the expected value in wall2 and wall3? I attached my case and detailed information pdf file. polyMesh1.zip file name convert polyMesh.z01 file. and then extract polyMesh.zip and polyMesh.z01 Thank you for your time and consideration. |
November 4, 2020, 11:32 |
Radiation filter for bands
Lucas Leocadio Battiston
Rep Power: 6 |
Hello everyone,
first, my appologise for my bad english. Well, im working with CHTmultiRegionFoam and my case have 3 regions, fluid/solid/fluid. I need filter radiation for bands in solid region. Anyone can help? OF-v2006. Rad model - fvDOM att, Lucas Battiston. |
November 4, 2020, 11:48 |
#3 | |
Rep Power: 6 |
This is my case. Thanks guys |
October 19, 2023, 06:38 |
changing filtro from fluid to solid
Elhaddad
Rep Power: 14 |
Hi all,
i have tried to change filtro to a solid region in teste2 and made all changes required, but no temperature change takes place on that region. I really need some help to understand how to put boundary conditions for all regions using fvDom. At least I need one working example with fvDom for surface to surface radiation. It will be very appreciated to get some help here! Thank you! |
Radiation model fvDoM get huge radiative heat flux | fxzf | OpenFOAM Running, Solving & CFD | 0 | April 23, 2018 11:28 |
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation | Zeppo | OpenFOAM Running, Solving & CFD | 16 | May 18, 2017 19:04 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 06:41 |
Radiation Modeling | Chris89 | CFX | 20 | August 14, 2014 08:51 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
