layerAdditionRemoval not adding or removing 🤔
Old   December 13, 2018, 16:21
Question layerAdditionRemoval not adding or removing 🤔
Sean Gorry
Sean95 is on a distinguished road
I'm working on a simple case that models compression in a cylinder. There is a moving wall whose velocity is read in from a .dat file. I had hoped to use lAR to deal with the mesh deformation, but I can't get it to work. When I run the case there are no errors, etc., the mesh is really coarse just to reduce simulation time to see if lAR is working. The case files are attached, and any help would be greatly appreciated as I've gone over several tutorials but can't see where my mistake is. The geometry is 260mm*25mm*1mm, and the mesh was generated in ANSYS with an element size of 2e-3.
Thanks
Sean95 is offline   Reply With Quote
Old   December 18, 2018, 08:40
Sean Gorry
After doing some more research, I found out that layer addition removal will only work with some mesh motion solvers. I found a good resource that goes through dynamic meshing in OpenFOAM http://www.tfd.chalmers.se/~hani/kur...AM-rapport.pdf
So if I want to use lAR I have to use changing topology solvers.
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 12:05
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 08:55
chtMultiRegionSimpleFoam 3D problem Lucie OpenFOAM Pre-Processing 2 June 21, 2016 06:23
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 09:43
