June 24, 2018, 14:03 |
Fan Boundary Conditions
Steven
Hi, I'm doing my first CFD model which is for a space that has a supply and an exhaust fan. There's a supply fan supplying X CFM into the space. There's an exhaust fan removing same amount from the space. What's the best approach to model this scenario? How do I input fan boundry conditions? Will this be a transients solver?
Thank you for your help in advance! |
July 6, 2018, 13:51 |
What's the goal for your case?
If you have one inlet and one outlet it's a standard case: I would put a fixed flow rate BC at the inlet and a fixed static pressure at the outlet, let's say a negative value, as for this patch the "fan" is sucking. You can also change these values and see what happens. |
fan boundry conditions |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
Please i need help: Set of boundary conditions for inflow with fan. | HAJ256 | FLUENT | 1 | March 14, 2013 10:11 |
