How to use a nonuniform boundary consitions
Old   December 28, 2017, 09:31
Default How to use a nonuniform boundary consitions
Qihao Jiang
Qihao is on a distinguished road
hello,
I am doing a simulation which the pressure in the top boundary is nonuniform, It varies with x direction and I calculated it use another software, it generate a file which consist the pressure value with different x direction values. the time is keep constant, the pressure just vary along x direction. Now I want to use this file as the boundary condition for another part. and try to use nonuniform List<Scalar>, but it has some errors, I do not why? can this method solve my problem? or I should consider another boundary conditions?
the error is wrong token type - expected Scalar, found on line 109 the punctuation token ')'
| \\ / O peration | Version: 5.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
front
type empty;
cyc_left
type cyclic;
top
type fixedValue;
value nonuniform List<scalar>
78
0.000
0.043
0.158
0.311
0.482
0.663
0.845
1.022
1.187
1.334
1.460
1.561
1.637
1.690
1.723
1.737
1.735
1.717
1.688
1.648
1.599
1.543
1.480
1.412
1.340
1.263
1.183
1.099
1.012
0.922
0.829
0.733
0.633
0.531
0.425
0.315
0.201
0.083
-0.041
-0.172
-0.310
-0.457
-0.615
-0.789
-0.982
-1.210
-1.469
-1.853
-2.185
-2.948
-2.923
-2.011
-1.717
-1.562
-1.437
-1.320
-1.209
-1.101
-0.996
-0.894
-0.797
-0.702
-0.610
-0.521
-0.437
-0.358
-0.285
-0.220
-0.152
-0.065
-0.017
bottom
type zeroGradient;
back
type empty;
cyc_right
type cyclic;
Qihao is offline   Reply With Quote
Old   December 28, 2017, 11:17
Taher Chegini
Taataa is on a distinguished road
In the list you declared the number of values to 78 but there are 71 numbers, they should be the same.
Taataa is offline   Reply With Quote
Old   December 28, 2017, 11:23
Qihao Jiang
I find this mistake, and when I increase the same number, it woks, but it still have some mistakes. and I want to consult you just now in the last questions you helped me,it will be more specific, and now I need to do interpolation of these discrete values, then use this as boundary conditions for another boundary, Do you have some methods about this?
Old   December 28, 2017, 11:42
clapointe is on a distinguished road
swak4Foam is a great utility that can be used to generate boundary conditions.
http://openfoamwiki.net/index.php/Contrib/swak4Foam
clapointe is offline   Reply With Quote
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 02:54
