OpenFOAM version comparison: v1706 versus 2.x 3.x and 4.x? |
October 18, 2017, 22:02 |
Mateus
I'm new to open foam and decided to go along with the windows version instead of redoing dual boot. The current version stated is v1706, but how does that compare to versions 2.x 3.x and 4.x that everyone seems to talk about in the forums and videos. I'm having some problems using older codes and this seems to be key in order to solve it.
December 30, 2017, 14:10 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: You will have to look into the changes made in the source code of OpenFOAM between versions.
On the top right corner of the main page at https://openfoamwiki.net - you can find links to all of the release notes for each version, which should help you at least start getting a bit of orientation on what changed from one version to another. There are also a couple of pages that help guide on the changes made between more recent versions:
[cfMesh] Compiling cfMesh with OpenFOAM 4.x | dkokron | OpenFOAM Community Contributions | 16 | August 15, 2018 12:26 |
Worse accuracy in LES models than in RANS models | dferrando | OpenFOAM Running, Solving & CFD | 0 | August 30, 2017 05:56 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
openfoam wich version use in my case | efirvida | OpenFOAM Pre-Processing | 3 | December 3, 2016 10:03 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
