Jet Engine case, initiating a detonation wave, and reactingParcelFoam errors |
March 11, 2017, 05:05 |
Robert Huang
Rep Power: 9 |
Hi OpenFOAM community,
I am trying to simulate a rotational detonation engine, except I am getting many errors and need help with starting the detonation wave. CheckMesh output: Code:
checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : checkMesh Date : Mar 11 2017 Time : 00:42:57 Host : "robert-Lenovo-G580" PID : 7901 Case : /home/robert/RDESim nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 44976 faces: 488140 internal faces: 474684 cells: 240706 faces per cell: 4 boundary patches: 1 point zones: 0 face zones: 2 cell zones: 3 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 240706 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology defaultFaces 13456 6730 ok (closed singly connected) Checking geometry... Overall domain bounding box (-65 -64.99995 0) (65 64.99994 80) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-4.958124e-18 -2.418597e-19 2.611782e-16) OK. Max cell openness = 4.504071e-16 OK. Max aspect ratio = 20.56824 OK. Minimum face area = 0.1640221. Maximum face area = 131.0312. Face area magnitudes OK. Min volume = 0.04628868. Max volume = 199.7307. Total volume = 1052052. Cell volumes OK. Mesh non-orthogonality Max: 80.69549 average: 19.35907 *Number of severely non-orthogonal (> 70 degrees) faces: 141. Non-orthogonality check OK. <<Writing 141 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 1.820535 OK. Coupled point location match (average 0) OK. Mesh OK. End Error #1: Code:
DILUPBiCG: Solving for Ux, Initial residual = 0.01593041, Final residual = 3.321646e-05, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.01461341, Final residual = 1.355258e-05, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.03112335, Final residual = 1.287348e-06, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::EulerImplicit<Foam::chemistryModel<Foam::rhoChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::solve(Foam::Field<double>&, double&, double&, double&, double&) const at ??:? #4 double Foam::chemistryModel<Foam::rhoChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::solve<Foam::UniformField<double> >(Foam::UniformField<double> const&) at ??:? #5 Foam::chemistryModel<Foam::rhoChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::solve(double) at ??:? #6 Foam::combustionModels::laminar<Foam::combustionModels::rhoChemistryCombustion>::correct() at ??:? #7 Foam::combustionModels::PaSR<Foam::combustionModels::rhoChemistryCombustion>::correct() at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? Code:
FOAM Warning : From function void Foam::CentredFitSnGradData<Polynomial>::calcFit(Foam::scalarList&, const Foam::List<Foam::Vector<double> >&, Foam::scalar, Foam::scalar, Foam::label) [with Polynomial = Foam::linearFitPolynomial; Foam::scalarList = Foam::List<double>; Foam::scalar = double; Foam::label = int] in file lnInclude/CentredFitSnGradData.C at line 158 Floating point exception (core dumped) Code:
Warning #2: smoothSolver: Solving for Ux, Initial residual = 0.03141642, Final residual = 3.558397e-09, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.01473086, Final residual = 1.896657e-09, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.0291702, Final residual = 4.048035e-09, No Iterations 1 --> FOAM Warning : From function Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::RASModels::SpalartAllmaras<BasicTurbulenceModel>::epsilon() const [with BasicTurbulenceModel = Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > >] in file ../turbulenceModels/lnInclude/SpalartAllmaras.C at line 325 Turbulence kinetic energy dissipation rate not defined for Spalart-Allmaras model. Returning zero field Code:
--> FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::scalar) const [with EquationOfState = Foam::perfectGas<Foam::specie>; Foam::scalar = double] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 105 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 189.5443 --> FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::scalar) const [with EquationOfState = Foam::perfectGas<Foam::specie>; Foam::scalar = double] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 105 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 188.6775 --> FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::scalar) const [with EquationOfState = Foam::perfectGas<Foam::specie>; Foam::scalar = double] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 105 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 196.8531 --> FOAM Warning : From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::scalar) const [with EquationOfState = Foam::perfectGas<Foam::specie>; Foam::scalar = double] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 105 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 196.468 fvSolutions: https://www.dropbox.com/s/93i2qx11ae...vSolution?dl=0 fvSchemes: https://www.dropbox.com/s/volce020cz...fvSchemes?dl=0 Sincerely, HRobertHS Last edited by HRobertHS; March 11, 2017 at 15:55. Reason: added fvSchemes and fvSolutions for easier download |
March 11, 2017, 15:49 |
Tried so far:
Robert Huang
Rep Power: 9 |
I tried switching my thermoType model to
thermoType { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo econst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Code:
thermoType { type heRhoThermo; mixture reactingMixture; transport sutherland; thermo janaf; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } For this one: Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" #2 ? in "/lib64/libc.so.6" #3 std::string::swap(std::string&) in "/opt/OpenFOAM/ThirdParty-v1612+/platforms/linux64/gcc-4.8.5/lib64/libstdc++.so.6" #4 Foam::word::operator=(std::string const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so" #5 Foam::basicThermo::splitThermoName(Foam::word const&, int) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so" #6 Foam::autoPtr<Foam::rhoChemistryModel> Foam::basicChemistryModel::New<Foam::rhoChemistryModel>(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so" #7 Foam::rhoChemistryModel::New(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so" #8 Foam::combustionModels::rhoChemistryCombustion::rhoChemistryCombustion(Foam::word const&, Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libcombustionModels.so" #9 Foam::combustionModels::laminar<Foam::combustionModels::rhoChemistryCombustion>::laminar(Foam::word const&, Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libcombustionModels.so" #10 Foam::combustionModels::PaSR<Foam::combustionModels::rhoChemistryCombustion>::PaSR(Foam::word const&, Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libcombustionModels.so" #11 Foam::combustionModels::rhoCombustionModel::adddictionaryConstructorToTable<Foam::combustionModels::PaSR<Foam::combustionModels::rhoChemistryCombustion> >::New(Foam::word const&, Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libcombustionModels.so" #12 Foam::combustionModels::rhoCombustionModel::New(Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libcombustionModels.so" #13 ? in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam" #14 __libc_start_main in "/lib64/libc.so.6" #15 ? in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam" Segmentation fault (core dumped) |
March 11, 2017, 21:23 |
Robert Huang
Rep Power: 9 |
Please help.... I tried creating a new mesh and forming a patch from a partition in SALOME. The detonation patch doesn't register and OpenFOAM creates a default patch for it along with many other cells. I tried changing some parameters around, but still get the same thing... I then tried to use simFlow and obtain this:
