March 1, 2017, 23:24 |
Mesh quality issue
JIN WEIGUO
Rep Power: 10 |
Hi Friends,
I'm having an issue of mesh quality. If you look at the two figures I attached, the meshes at the transition areas between buildings and open spaces are quite coarse. Actually when I view the velocity result, the meshes look even worse and not fluent at all. Can anyone help tell the reason and advice? I used snappyHex mesh to generate meshes. Thanks in advance. Mark |
March 7, 2017, 00:08 |
JIN WEIGUO
Rep Power: 10 |
Can anyone give any advice?
March 7, 2017, 01:08 |
Rep Power: 16 |
You have a pretty big change in your mesh size over a small area. Try to make the change in size more gradual. Cheers, Antimony |
March 7, 2017, 04:12 |
#4 | |
JIN WEIGUO
Rep Power: 10 |
Hi Antimony, Thanks for your reply. I tried to increase 'ncellsbetweenlayers' from 5 to 15. Mesh quality looks better now. But still I can see two different colors (U magnitude) at the transient potion of two adjacent layers. Seems like somewhere wrong with my ground boundary condition. Regards, Mark |
March 7, 2017, 04:38 |
#5 | |
JIN WEIGUO
Rep Power: 10 |
Hi Antimony, Actually, that 'color contrast' phenomenon at transient portion only happens on the surface within one cell distance from coordinate Z=0. |
[mesh manipulation] Does extrudeMesh affect mesh quality in non extruded cells? | Blanco | OpenFOAM Meshing & Mesh Conversion | 3 | February 25, 2023 09:19 |
[ICEM] Unexplained changes of mesh quality and blocking approach | salumi | ANSYS Meshing & Geometry | 9 | November 23, 2016 05:14 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
early stall, poor convergence, and mesh quality | everest | CFX | 2 | May 12, 2010 17:27 |
mesh quality and independency..!?? | michelle | CFX | 0 | October 15, 2007 06:50 |
