maximum number of faces?
Old   January 5, 2017, 07:49
Default maximum number of faces?
Moritz
Mojo is on a distinguished road
Hi there,
I already asked this questions in a different thread (https://www.cfd-online.com/Forums/op...faces-shm.html), but I think it's not limited to snappyHexMesh so I post my question here as well.
What is the maximum number of faces in openfoam?
During meshing I get a negative number of faces:
After refinement gap refinement iteration 1 : cells: 888 490 165  faces: -1 563 835 164  points:952606417
shortly afterwards snappyHexMesh crashes.
My idea is, that the number of faces is stored as a 32 Bit Integer. So the negative face number has something to do with the 32 Bit Integer Limit, because die number of faces of would be higher in this example.
I tried to find something in the source code, but I'm not familiar with it yet, so it's hard for me to find anything. In the snappyHexMesh.C Source code I found where faces are gatherd (line 462)
// Gather all faces
List<faceList> gatheredFaces(Pstream::nProcs());
gatheredFaces[Pstream::myProcNo()] = allBoundary.localFaces();
forAll(gatheredFaces[Pstream::myProcNo()], i)
inplaceRenumber(pointToGlobal, gatheredFaces[Pstream::myProcNo()][i]);
Pstream::gatherList(gatheredFaces);
But I didn't find the "number of faces" for the output or a maximum number of faces.
Maybe someone who's more familiar with the source code could give me a hint?
Thanks for your help!
Regards
Moritz
Mojo is offline   Reply With Quote
Old   January 5, 2017, 09:53
Moritz
okay, I figured it out myself. Just in case anybody is interested:
Starting from line 2692 in the meshRefinement.C Source Code (http://cpp.openfoam.org/v4/a07399_source.html) the output for the number of faces is defined. The number of faces is stored in the label "nMasterFaces".
With echo $WM_LABEL_SIZE (http://cpp.openfoam.org/v4/a09200_source.html) you can check the size of your labels, 32 or 64 Bit.
In my case its 32 Bit, so I assume this is the reason why I get a negative face number and sHM crashed.
Depending on your system (if 64Bit is possible or not) you can change the LABEL_SIZE in your bashrc file.
Just for completness, the link to my other post where I asked this question: https://www.cfd-online.com/Forums/op...faces-shm.html
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 16:05
