Woo Hyeon Cho
I recently faced "Wedge Patch '*' is not planer error" and I solved it.
I'd like to let other know how I solved that error.
FYI I doesn't have much experience in openFoam and other CFD software.
But I think this information should be written.
When you createBaffles, checkMesh or execute solve command.
Most of the time it happens. If you didn't properly meshing your stuff.
Buy the way what I mean "Wedge Patch '*' is not planer error" is something like below.
--> FOAM Warning :
From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBu ffers&)
in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 69
Wedge patch 'wedge1' is not planar.
At local face at (14.3435 -1646.04 0.626253) the normal (-0.0436194 -3.09103e-17 0.999048) differs from the average normal (-0.0436195 -4.45833e-08 0.999048) by 2.40193e-14
Either correct the patch or split it into planar parts
--> FOAM Warning :
At local face at (10.6613 -277.657 0.465485) the normal (-0.0436194 -1.58485e-17 0.999048) differs from the average normal (-0.0436195 -4.45833e-08 0.999048) by 2.40193e-14
--> FOAM Warning :
At local face at (2.34513 -243.263 0.102391) the normal (-0.0436194 -1.28862e-17 0.999048) differs from the average normal (-0.0436195 -4.45833e-08 0.999048) by 2.40193e-14
Let me show you how I eradicate this kind of annoying errors.
1. Check and change your mesh
Personally, I use Gmsh to mesh my stuff. That's because it is easy for me to use. Anyway, I didn't check my mesh properly back then.
I create the point geometry with my matlab code and implemented it to Gmsh to create duct simulation for me.
Here are my codes.
It didn't work.
// Gmsh project created on Mon Aug 8 12:40:08 2016
// Gmsh project created on Thu Aug 4 20:38:08 2016
// INPUT
Point(1) = { 26.85209117 , -47.71562961 , 0 };
Point(2) = { 26.99588777 , -43.95394396 , 0 };
Point(3) = { 26.93422936 , -40.18652033 , 0 };
Point(4) = { 26.6675852 , -36.44203111 , 0 };
Point(5) = { 26.19798461 , -32.74897411 , 0 };
Point(6) = { 25.52900154 , -29.13545573 , 0 };
Point(7) = { 24.66572736 , -25.62897702 , 0 };
Point(8) = { 23.61473209 , -22.25622441 , 0 };
Point(9) = { 22.38401446 , -19.04286657 , 0 };
Point(10) = { 20.98294096 , -16.01335911 , 0 };
Point(11) = { 19.42217461 , -13.1907584 , 0 };
Point(12) = { 17.71359378 , -10.59654613 , 0 };
Point(13) = { 15.87020181 , -8.250465843 , 0 };
Point(14) = { 13.90602802 , -6.17037261 , 0 };
Point(15) = { 11.83602096 , -4.3720972 , 0 };
Point(16) = { 9.675934638 , -2.869325575 , 0 };
Point(17) = { 7.442208607 , -1.673494735 , 0 };
Point(18) = { 5.151842875 , -0.793705675 , 0 };
Point(19) = { 2.822268508 , -0.23665412 , 0 };
Point(20) = { 0.471214974 , -0.006579569 , 0 };
Point(21) = { -2.199003211 , -0.033583218 , 0 };
Point(22) = { -6.594330487 , -0.302187587 , 0 };
Point(23) = { -10.98162359 , -0.839069071 , 0 };
Point(24) = { -15.35553727 , -1.643573563 , 0 };
Point(25) = { -19.7107426 , -2.714720899 , 0 };
Point(26) = { -24.04193342 , -4.05120605 , 0 };
Point(27) = { -28.34383285 , -5.651400715 , 0 };
Point(28) = { -32.61119968 , -7.513355303 , 0 };
Point(29) = { -36.8388348 , -9.63480131 , 0 };
Point(30) = { -41.02158746 , -12.01315408 , 0 };
Point(31) = { -45.15436164 , -14.64551596 , 0 };
Point(32) = { -49.23212219 , -17.52867981 , 0 };
Point(33) = { -53.24990098 , -20.65913296 , 0 };
Point(34) = { -57.20280297 , -24.03306142 , 0 };
Point(35) = { -61.08601215 , -27.64635458 , 0 };
Point(36) = { -64.89479744 , -31.4946102 , 0 };
Point(37) = { -68.62451841 , -35.57313977 , 0 };
Point(38) = { -72.27063098 , -39.87697423 , 0 };
Point(39) = { -75.82869292 , -44.40087003 , 0 };
Point(40) = { -79.29436927 , -49.1393155 , 0 };
Point(41) = { -82.66343765 , -54.08653756 , 0 };
Point(42) = { -85.93179337 , -59.23650879 , 0 };
Point(43) = { -89.09545443 , -64.58295475 , 0 };
Point(44) = { -92.1505664 , -70.11936161 , 0 };
Point(45) = { -95.09340711 , -75.83898411 , 0 };
Point(46) = { -97.92039114 , -81.73485377 , 0 };
Point(47) = { -100.6280743 , -87.79978739 , 0 };
Point(48) = { -103.2131576 , -94.02639578 , 0 };
Point(49) = { -105.6724916 , -100.4070928 , 0 };
Point(50) = { -108.0030799 , -106.9341045 , 0 };
Point(51) = { -110.2020831 , -113.5994787 , 0 };
Point(52) = { -112.266822 , -120.3950948 , 0 };
Point(53) = { -114.1947812 , -127.3126733 , 0 };
Point(54) = { -115.9836115 , -134.3437862 , 0 };
Point(55) = { -117.6311337 , -141.4798671 , 0 };
Point(56) = { -119.1353405 , -148.7122219 , 0 };
Point(57) = { -120.4943993 , -156.0320391 , 0 };
Point(58) = { -121.7066541 , -163.4304006 , 0 };
Point(59) = { -122.7706282 , -170.8982925 , 0 };
Point(60) = { -123.6850251 , -178.4266165 , 0 };
Point(61) = { -124.4487309 , -186.0062005 , 0 };
Point(62) = { -125.0608151 , -193.6278098 , 0 };
Point(63) = { -125.520532 , -201.2821587 , 0 };
Point(64) = { -125.8273214 , -208.9599216 , 0 };
Point(65) = { -125.9808096 , -216.6517444 , 0 };
Point(66) = { -125.9808096 , -224.3482556 , 0 };
Point(67) = { -125.8273214 , -232.0400784 , 0 };
Point(68) = { -125.520532 , -239.7178413 , 0 };
Point(69) = { -123.020532 , -248.1032949 , 0 };
Point(70) = { -120.520532 , -256.4887485 , 0 };
Point(71) = { -118.020532 , -264.8742021 , 0 };
Point(72) = { -115.520532 , -273.2596557 , 0 };
Point(73) = { -113.020532 , -281.6451093 , 0 };
Point(74) = { -110.520532 , -290.0305629 , 0 };
Point(75) = { -108.020532 , -298.4160165 , 0 };
Point(76) = { -105.520532 , -306.8014701 , 0 };
Point(77) = { -103.020532 , -315.1869237 , 0 };
Point(78) = { -100.520532 , -323.5723773 , 0 };
Point(79) = { -98.02053196 , -331.9578309 , 0 };
Point(80) = { -95.52053196 , -340.3432846 , 0 };
Point(81) = { -93.02053196 , -348.7287382 , 0 };
Point(82) = { -90.52053196 , -357.1141918 , 0 };
Point(83) = { -88.02053196 , -365.4996454 , 0 };
Point(84) = { -85.52053196 , -373.885099 , 0 };
Point(85) = { -83.02053196 , -382.2705526 , 0 };
Point(86) = { -80.52053196 , -390.6560062 , 0 };
Point(87) = { -78.02053196 , -399.0414598 , 0 };
Point(88) = { -75.52053196 , -407.4269134 , 0 };
Point(89) = { -73.02053196 , -415.812367 , 0 };
Point(90) = { -70.52053196 , -424.1978206 , 0 };
Point(91) = { -68.02053196 , -432.5832742 , 0 };
Point(92) = { -65.52053196 , -440.9687278 , 0 };
Point(93) = { -63.02053196 , -430.3256096 , 0 };
Point(94) = { -60.52053196 , -419.6824915 , 0 };
Point(95) = { -58.02053196 , -409.0393733 , 0 };
Point(96) = { -55.52053196 , -398.3962551 , 0 };
Point(97) = { -53.02053196 , -387.7531369 , 0 };
Point(98) = { -50.52053196 , -377.1100187 , 0 };
Point(99) = { -48.02053196 , -366.4669005 , 0 };
Point(100) = { -45.52053196 , -355.8237823 , 0 };
Point(101) = { -43.02053196 , -345.1806641 , 0 };
Point(102) = { -40.52053196 , -334.5375459 , 0 };
Point(103) = { -38.02053196 , -323.8944277 , 0 };
Point(104) = { -35.52053196 , -313.2513096 , 0 };
Point(105) = { -33.02053196 , -302.6081914 , 0 };
Point(106) = { -30.52053196 , -291.9650732 , 0 };
Point(107) = { -28.02053196 , -281.321955 , 0 };
Point(108) = { -25.52053196 , -270.6788368 , 0 };
Point(109) = { -23.02053196 , -260.0357186 , 0 };
Point(110) = { -20.52053196 , -249.3926004 , 0 };
Point(111) = { -18.02053196 , -238.7494822 , 0 };
Point(112) = { -15.52053196 , -228.106364 , 0 };
Point(113) = { -13.02053196 , -217.4632458 , 0 };
Point(114) = { -10.52053196 , -206.8201277 , 0 };
Point(115) = { -8.02053196 , -196.1770095 , 0 };
Point(116) = { -5.52053196 , -185.5338913 , 0 };
Point(117) = { -3.02053196 , -174.8907731 , 0 };
Point(118) = { -0.52053196 , -164.2476549 , 0 };
Point(119) = { 1.97946804 , -153.6045367 , 0 };
Point(120) = { 4.47946804 , -142.9614185 , 0 };
Point(121) = { 6.97946804 , -132.3183003 , 0 };
Point(122) = { 9.47946804 , -121.6751821 , 0 };
Point(123) = { 11.97946804 , -111.0320639 , 0 };
Point(124) = { 14.47946804 , -100.3889458 , 0 };
Point(125) = { 16.97946804 , -89.74582756 , 0 };
Point(126) = { 19.47946804 , -79.10270937 , 0 };
Point(127) = { 21.97946804 , -68.45959118 , 0 };
Point(128) = { 24.47946804 , -57.81647299 , 0 };
Line(1) = {1:128,1};
Point(131) = {0, -2000, 0, 1.0};
Point(134) = {0, 1500, 0, 1.0};
Point(135) = {2000, 1500, 0, 1.0};
Point(136) = {2000, -2000, 0, 1.0};
Line(3) = {136, 131};
Line(4) = {136, 135};
Line(5) = {135, 134};
Translate {300, 0, 0} {
Line{1};
Point(137) = {0, -248.1, 0, 1.0};
Line(6) = {131, 137};
Line(7) = {137, 134};
Line(8) = {137, 69};
Line Loop(9) = {-8,7,-5,-4,3,6,8};
Line Loop(10) = {7, -5, -4, 3, 6};
Line Loop(11) = {1};
Plane Surface(12) = {9, 11};
Rotate {{0,1,0},{0,0,0},2.5*Pi/180.0}
Surface{12};
new_entities[] = Extrude {{0,1,0},{0,0,0},-5*Pi/180.0}
Surface{12};
Layers{1};
Recombine;
Physical Surface("wedge0") = {12};
Physical Surface("wedge1") = {new_entities[0]};
Physical Surface("baffle") = {new_entities[2]};
Physical Surface("inlet") = {new_entities[3]};
Physical Surface("tunnel") = {new_entities[4]};
Physical Surface("outlet") = {new_entities[5]};
Physical Surface("duct") = {new_entities[7]};
Physical Volume("AIR") = {1};
Transfinite Line {7, 6, 18, 3, 16, 5, 17, 4} = 50 Using Progression 1;
Transfinite Line {8, 14} = 40 Using Progression 1;
Transfinite Line {23} = 20 Using Progression 1;
Transfinite Line {21, 1} = 300 Using Progression 1;
It worked.
Point(1) = { 326.8521 , -47.7156 , 0 };
Point(2) = { 326.1980 , -32.7490 , 0 };
Point(3) = { 322.3840 , -19.0429 , 0 };
Point(4) = { 315.8702 , -8.2505 , 0 };
Point(5) = { 307.4422 , -1.6735 , 0 };
Point(6) = { 297.8010 , -0.0336 , 0 };
Point(7) = { 286.8294 , -1.2079 , 0 };
Point(8) = { 275.9581 , -4.0512 , 0 };
Point(9) = { 265.2697 , -8.5418 , 0 };
Point(10) = { 254.8456 , -14.6455 , 0 };
Point(11) = { 244.7652 , -22.3159 , 0 };
Point(12) = { 235.1052 , -31.4946 , 0 };
Point(13) = { 225.9391 , -42.1118 , 0 };
Point(14) = { 217.3366 , -54.0865 , 0 };
Point(15) = { 209.3632 , -67.3278 , 0 };
Point(16) = { 202.0796 , -81.7349 , 0 };
Point(17) = { 195.5413 , -97.1980 , 0 };
Point(18) = { 189.7979 , -113.5995 , 0 };
Point(19) = { 184.8933 , -130.8146 , 0 };
Point(20) = { 180.8647 , -148.7122 , 0 };
Point(21) = { 177.7427 , -167.1562 , 0 };
Point(22) = { 175.5513 , -186.0062 , 0 };
Point(23) = { 174.3069 , -205.1187 , 0 };
Point(24) = { 174.0192 , -224.3483 , 0 };
Point(25) = { 174.6902 , -243.5485 , 0 };
Point(26) = { 179.6902 , -260.0080 , 0 };
Point(27) = { 184.6902 , -276.4675 , 0 };
Point(28) = { 189.6902 , -292.9269 , 0 };
Point(29) = { 194.6902 , -309.3864 , 0 };
Point(30) = { 199.6902 , -325.8459 , 0 };
Point(31) = { 204.6902 , -342.3053 , 0 };
Point(32) = { 209.6902 , -358.7648 , 0 };
Point(33) = { 214.6902 , -375.2243 , 0 };
Point(34) = { 219.6902 , -391.6838 , 0 };
Point(35) = { 224.6902 , -408.1432 , 0 };
Point(36) = { 229.6902 , -424.6027 , 0 };
Point(37) = { 234.6902 , -441.0622 , 0 };
Point(38) = { 239.6902 , -419.7222 , 0 };
Point(39) = { 244.6902 , -398.3822 , 0 };
Point(40) = { 249.6902 , -377.0422 , 0 };
Point(41) = { 254.6902 , -355.7022 , 0 };
Point(42) = { 259.6902 , -334.3622 , 0 };
Point(43) = { 264.6902 , -313.0222 , 0 };
Point(44) = { 269.6902 , -291.6823 , 0 };
Point(45) = { 274.6902 , -270.3423 , 0 };
Point(46) = { 279.6902 , -249.0023 , 0 };
Point(47) = { 284.6902 , -227.6623 , 0 };
Point(48) = { 289.6902 , -206.3223 , 0 };
Point(49) = { 294.6902 , -184.9823 , 0 };
Point(50) = { 299.6902 , -163.6423 , 0 };
Point(51) = { 304.6902 , -142.3023 , 0 };
Point(52) = { 309.6902 , -120.9624 , 0 };
Point(53) = { 314.6902 , -99.6224 , 0 };
Point(54) = { 319.6902 , -78.2824 , 0 };
Point(55) = { 324.6902 , -56.9424 , 0 };
Line(56) = {1:55,1};
Line Loop(57) = {56};
Point(58) = {0, -2000, 0, 100};
Point(59) = {0, 1500, 0, 100};
Point(60) = {2000, 1500, 0, 100};
Point(61) = {2000, -2000, 0, 100};
Point(62) = {0, -243.5, 0, 100};
Line(63) = {25, 62};
Line(64) = {62, 59};
Line(65) = {59, 60};
Line(66) = {60, 61};
Line(67) = {61, 58};
Line(68) = {58, 62};
Line(69) = {62, 25};
Line Loop(70) = {63:69};
Plane Surface(71) = {57, 70};
Transfinite Line {64, 68} = 40 Using Progression 1;
Transfinite Line {67, 65} = 40 Using Progression 1;
Transfinite Line {66} = 60 Using Progression 1;
Transfinite Line {63} = 20 Using Progression 1;
Transfinite Line {56} = 600 Using Progression 1;
Surface{71};
Surface{71};
Layers{1};
Recombine;
Physical Surface("wedge0") = {71};
Physical Surface("outlet") = {new_entities[4]};
Physical Surface("tunnel") = {new_entities[5]};
Physical Surface("inlet") = {new_entities[6]};
Physical Surface("duct") = {new_entities[2]};
Physical Surface("baffle") = {new_entities[7]}; // or 3
Do you see the difference?
I changed the digit number. I bring it down to 4 digit after 0. I rounded it up.
The digit number does matters. I didn't know that.
-> Check your mesh geometry and change the geometry digit down to 4 digit at least.
2. Check and change your setting.
Actually, I didn't use this solution to solve my problem but I saw someone who solve their problem with this way. I think in my case, I was pretty bad at first(mesh geometry digit problem). But, It it work for someone who has a light problem.
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
applicationClass pimpleFoam;
startFrom latestTime;
startTime 0;
endTime 1;
stopAt endTime;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 0.01;
cycleWrite 0;
writeFormat binary; //<-KEEP binary
writePrecision 6; //<- Make it up to 12 or more if you want
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 20;
I think that's it for treating this kind of problem. If you face that error.
You may remember 2 things.
1.check mesh
2.check setting
Thank you
